Networks new ADSL modem?
Discussion in 'Hardware' started by ocha, 1 Feb 2002.
  1. ocha
    ocha Minimodder
    29 Dec 2001
    Is there any other MODEMS that you can use with BT's ADSL cos the actel ones they give you are crap? got any idea an where to buy em neone?
  2. billy beard
    billy beard What's a Dremel?
    3 Jan 2002
    take the adsl modem and throw it at the nearest bt workman you find
  3. R121
    R121 What's a Dremel?
    10 Nov 2001
    you can use dlink internal modems but if you have more than 1 computer it is better to get a ADSL router
    Netgear
    Efficient Networks EN 5861
    D-Link DSL-504 or DSL-500
    ZyXEL Prestige 645 ADSL Modems and Routers
    it all depends what your going to use it for and how much your willing to spend they start form £80 and they go upto £280
    the question is how much do you hate HATE the frog (alcatel USB MODEM)
  4. BannedMojo
    BannedMojo Banned
    14 Jan 2002
    Question time:
    In NZ I got this ADSL internal PCI card. Description:
    "Speedstream3020 ADSL Internal Modem"
    Efficient Networks Inc.
    Its got an RJ11 connector, and a whopping big green LED.
    Line Code: DMT, FDM, ADSL
    Line Rate: up to 640kbps upstream 6.1mbps downstream
    As for serial numbers on the board:
    ASSY 030-3520-001 REV 5.0
    Anyone heard of this thing? I don't know anything about it - It wass given to me...
  5. R121
    10 Nov 2001
  6. BannedMojo
    BannedMojo Banned
    14 Jan 2002
    I wanted to knwo if any has it and/or sues it with ADSL here - Its from NZ so I was unsure if it would work. But not XP compatible :(
  7. R121
    10 Nov 2001
    Im not to sure but i dont see why it cant work over here your best bet would be to e-mail efficent UK .
  8. herbs
    herbs Nobody but us chickens
    7 May 2001
  9. Phil
    Phil What's a Dremel?
    19 Jul 2001
    www.plus.net and www.nildram.co.uk both do self-install ADSL which saves money by getting you to do most of the work - you have to provide your own ADSL modem too.....
  10. vipmehta
    vipmehta What's a Dremel?
    11 Feb 2002
  11. ocha
    ocha Minimodder
    29 Dec 2001
    hey everyone thanks for your help that is all very good. Just what i needed. I think I may go with a router+modem when I get the cash. Hopefully I wont invalidate my contract with BT hahahahhaha
  12. batsman
    batsman the quiet one
    14 Nov 2001
    i have the dabs value one on order only £90 with built on router 4 100Mbps ports will let you know if its any good.
    if it aint it's going back.
  13. therider
    therider What's a Dremel?
    11 Mar 2002
    just £90 whats the product code?
    I was gonna get the DSL-504 £170 on dabs.
  14. batsman
    14 Nov 2001
    you can't get it at the moment they have a problem getting them from the supplier.
    i am getting the DSL-500 from insight (only place with them "in stock") hopefully on monday.
    the 504 isn't out for a few more weeks and its pointless having 4 ports if its going straight into a smootwall, as mine will be.
