Scratch Build – In Progress [New Build Almost Complete] First time building a custom loop. All comments welcome.
Discussion in 'Project Logs' started by Stu @ MSD, 7 Mar 2012.
  1. Stu @ MSD
    Stu @ MSD What's a Dremel?
    6 Feb 2012
    Hi guys,
    Been around the forums and overclocking since the celeron and MMX days, but only recently got into the whole benchmarking thing and decided it was time to build a new machine up with some watercooling headroom, so, here we go.
    Case:
    Corsair Obsidian 800D
    Mobo:
    Asus Maximus Extreme IV - Z
    CPU:
    Intel Core i7-2600K
    GPU:
    3 x Sapphire Radeon 7970's
    RAM:
    16GB of Corsair Vengeance 1866MHz
    HDD:
    2x OCZ Vertex 3 Sata 6 SSD
    2x 1TB Western Digital Velociraptors
    PSU:
    XFX Pro 1250w Black gamer Edition
    Optical:
    Pioneer 12x Blu Ray Combo Drive
    Monitor:
    3 x Dell UltraSharp U2410 24" LCD
    OS:
    MS Windows 7 Ultimate 64bit
    Cooling & Monitoring
    CPU Block:
    EK Supreme HF Plexi EN
    Radiator:
    1 x EK Coolstream XT 360mm Copper Fins - Single Circuit
    Reservoir:
    XSPC Acrylic Dual 5.25 with pump inside
    Pumps:
    Alphacool VPP655 - D5 Pump
    Fans:
    3 x Scythe Gentle Typhoon 1850RPM - AP15s on the radiator.
    3x Corsair 140mm fans around the chassis.
    Fittings:
    Bitspower compression fittings
    Tubing:
    Masterkleer 59117 3/8" in red.
    Coolant:
    Feser Aqua - Ultra Pure Water
    Controller & Monitoring:
    Aquacomputer Aquaero 5 Pro
    Coolant temp monitored before and after radiator.
    Lighting:
    LED's and a UV inverter so far.
    Basic hardware and case...
    + water cooling parts.
    Case unwrapped..
    Some parts unwrapped...
    360mm radiator installed with 3x Scythe GT Ap15's
    Temperature monitoring for radiator inlet and exhaust
    Installing EK water block on the MOBO.
    Some pipes, and mobo installed.
    Sata hotswop bays are quite ingenius and lovely to wire up.
    Then a cover makes it all neat and tidy.
    Ready to power up...
    Up and running...
  2. Stu @ MSD
    6 Feb 2012
    Sorry, thought I had taken far more pictures than that, will get some more tonight of pumps and reservoiur setup etc.
    Comments on the above build are very much encouraged, good and bad.
    Moving forward...
    I want to deal with the following jobs...
    • Install my Aquaero pro tonight
    • Placement of the OCZ Vertex drives. (I think on the shelf below the 7970's would look wicked.)
    • Add a drain port somehow. - ideas welcome
    • Tidy up the wiring some more
    • Purchase and install cooling items for GPU's.
    • Figure out best way to fit a second rad for GPU's. (External is a viable option)
    • Investigate and purchase better 140mm fans.
    • Investigate wether chipset cooling is worthwhile on this MOBO
    Advice always very welcome. :)
  3. Stu @ MSD
    6 Feb 2012
    I am really looking forward to fitting this Aquaero tonight... it really looks the business!
    Animated Giff showing some features.
  4. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Thats some serieus hardware you got there man! A trifire with 7970:jawdrop:
    Whats that Hot swap unit you got btw, it looks realy usefull!
    Will any modding be done to the case?
  5. Stu @ MSD
    6 Feb 2012
    Thank you.
    The hotswap comes with the case, nice little board indeed, but sadly I cant get the SSD's to work with it due to alignment so have had to find a new home for them. (see below)
    Unsure on case mods just yet, need at least one more radiator when the GPU blocks start to go in, but may yet go external triple 360's.
    Far more importantly though, the damn Aquaero does not even power up... its dead. :(
    Some more pics for now...
    Interior with 2x SSD's installed. (ignore 2 temp monitor wires, will be moved when new aquaero is installed)
  6. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    Nice clean set up , =)
  7. AK71
    AK71 What's a Dremel?
    29 Jul 2011
    Only thing I would suggest is that it would look better if you changed the blue LEDs for red ones
  8. Stu @ MSD
    6 Feb 2012
    Thanks mate, I have bought red too, trying blue as every other piece of PC equipment in the room lights up blue, as you can see in the room image above. I will try red as well at some point though. :)
  9. AK71
    29 Jul 2011
    You're welcome. That's the problem now, almost everything seems to have at least one blue LED in it
  10. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    sounds to me like you have some LED's to mod :dremel:
  11. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    You can usually fit a 240 radiator in the floor of the 800D, pulling air in from the bottom. So I'd suggest going; Res, Pump, Gpus (It'd be sinful not to WC those.), Roof 360, CPU (And mobo, if you go fullcover block on it), 240 then Res again. Means you don't have to go through the hassle of wiring up two loops.
  12. Stu @ MSD
    6 Feb 2012
    Had a more extreme idea and most the parts will be here tomorrow and the final ones Friday so watch this space! ;)
