Other New PC stability issues
Discussion in 'Tech Support' started by Snubbs, 8 Mar 2013.
  1. Snubbs
    Snubbs CustomPC Migration victim....
    27 Mar 2009
    Hey,
    I built a PC for a friend about 2 months ago, however it's having some stability issues.
    Basically, every now and then it'll 'freeze' the image pauses, audio becomes a humm, and there's no response from keyboard and mouse. The only fix is a hard reboot.
    Some days it may happen 3 times, sometimes it'll be fine for 2 weeks.
    The spec is:
    i5 3570k
    Asus p8z77 motherboard
    8GB corsair xms3 ram
    128GB Samsung 830
    3TB drive (I think its a Seagate or WD)
    EVGA GTX 660 OC
    Branded PSU 700w (can't remember brand, possibly ocz or sea sonic)
    I've ram prime95 for a couple of hours, MSI Kombuster for an hour, memtest 86+ overnight for 6 passes. Temps all seem to stay reasonable, and no errors are given (other than GPU showing 105% TDP, thou I imagine that's due to the stock over clock or boost?)
    Any ideas as to how I can troubleshoot it further?
    I intend on doing a rebuild with new SATA cables just incase one is damaged due to cable-routing.
    Thanks, James
  2. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    Is the CPU overclocked?
    Have you made sure the ram timings in the bios are correct?
    And it would seem you need to check airflow to you GPU. Maybe downclock it? Faulty/badly seated cooler.
    Always good to check the sata cables :thumbup:
  3. Snubbs
    27 Mar 2009
    CPU is stock. Crazy thing is as well that I can't seem to make it crash
    Only odd thing it does, is the GPU seems to be putting the monitor to sleep after a minute or so, even thou power options have this disabled.
    The ram timings appear to be setup fine via the xmp profile as confirmed in CPU-Z.
    I'd have thought if it was the card, I'd have managed to at least cause artifacts in Kombuster...
    Thanks for suggestions - I'm going to rebuild before giving it him back (and down clock the gpu a tad) but kinda want to find the cause somehow... Any other stress tests you'd suggest?
  4. bulldogjeff
    2 Mar 2010
    It might be a GPU problem so make sure you have the latest drivers installed, or go the other way and roll back to the last one.
  5. jaydeee
    jaydeee What's a Dremel?
    25 Apr 2010
    Have you checked your system log?
    Hanging issue is one of the complicated issue to troubleshoot.
