Modding new power/hd window
Discussion in 'Modding' started by Sh00ter, 17 Nov 2003.
  1. Sh00ter
    Sh00ter What's a Dremel?
    13 Oct 2002
    been thinking for a while on somehow getting my clans tag on me pc somehow, toyed with a uv type applique but decided to go with something a little more permanent!
    diffused perspex with a hi-bright blu on each end and a couple of red led's i had kicking around on the bottom edge, and a lot of time with a dremel - although i must admit it all went pretty well as this is the first time ive done any fine work with it
    and with hd access
  2. Jivecat
    Jivecat What's a Dremel?
    26 Feb 2003
    Looks pretty smooth! Good job!
  3. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Nice detail on the logo :)
  4. WizardLock
    WizardLock What's a Dremel?
    15 Nov 2003
    Great job!! Looks awesome....
  5. mence
    mence What's a Dremel?
    27 Nov 2002
    very very clean mate, what'd you do the cut with?
    and i like the colours, well done
  6. Sh00ter
    13 Oct 2002
    thanks for the kind words!
    it was cut using a dremel with a cutting disc, the ends of each run were drilled and then it was all tidied up with some some grinding stones
    :D
