nukeduud [Update: 06-09-2004]
Discussion in 'Project Logs' started by KAMIKAZE-FREAK, 17 Jul 2004.
  1. CYRiX
    CYRiX What's a Dremel?
    4 Sep 2004
    change front side to green leds or vice versa.
  2. Thrillseekah
    Thrillseekah What's a Dremel?
    21 Oct 2004
    Nice mod. Would love to get my hands on one of those server cases. They rock. :rock: keep up the good work.
    Your going for watercooling ?
  3. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    thats 1 thing on the wish list
  4. Protius-X
    Protius-X What's a Dremel?
    31 May 2004
    That switch idea is awesome! Mind if I use it? Oh and it looks good so far. I'd make it look all mutated instead of the yellow and black stripes. Maybe have a mutated face or something?
  5. KAMIKAZE-FREAK
    30 May 2004
    No i dont mind if you use the idea
    i even DARE yah to make it better :D
    and i also thought about changing the idea to a flat front with lcd or something, and use a tube reservoir similar to _ferry_'s reservoir used with Project Chemical overdose
    and then paint it in a style that it looks like the reservoir leaked radioactive fluid allll over the case
  6. Protius-X
    31 May 2004
    Oh I'm going to make it better for sure! I'm using a drive face plate, muhahahahaha1!!!
  7. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    ive just got the same case from with dual p3 1gb of ram and a scsi array though they had to destroy the drives, its sat here waiting to be modded, i'll start it on day.
    i'll be following this project with interest.
  8. quentec
    quentec What's a Dremel?
    18 Aug 2004
    It's a very nice mod, but I think that's yellow and black hmmmm....it's not good idea for me, but if you like those climate :D
  9. Jokkocze
    Jokkocze What's a Dremel?
    16 Dec 2004
    hmm.. a better looking way for that ccfl button to sit there would be to make that hole in the grille bigger.. if there's room
  10. KAMIKAZE-FREAK
    30 May 2004
    wich hole in the grille?
  11. Xhiz
    Xhiz What's a Dremel?
    28 Oct 2004
    Dude where did you get that case form? I'd love my first mod to be on one of them cases :idea:
  12. KAMIKAZE-FREAK
    30 May 2004
    i bought it from a dutch clone of ebay
    for 30 euro's
    its a chenbro case
    maby you can talk with a chenbro dealer? :idea:
  13. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    i`m waiting for the painting job :)
  14. Anthony
    Anthony What's a Dremel?
    6 Jan 2005
    I dont like your avatar picture, but i like your computer :D :D
    And the thing i like, is that aircontroller panel ...
  15. KAMIKAZE-FREAK
    30 May 2004
    send me money and ill give you the pictures
    i plan on powdercoating it
  16. Kumo
    18 Oct 2004
    Hehehehehehee....
  17. Cookie Monster
    27 Aug 2003
    How did you remove the top plastic panel? like i said ive got the same case but cant work out at the moment how to get it off without the use of a sledge hammer :rock:
  18. KAMIKAZE-FREAK
    30 May 2004
    i removed the lock
    and then just slided it off
