P4 help needed
Discussion in 'Hardware' started by JoKeR, 26 Sep 2004.
  1. JoKeR
    JoKeR What's a Dremel?
    23 Apr 2004
    Hi guys can anyone out there give me some help.
    just installed a abit IC7 mobo with a 3.2 P4 everthing went well until i noticed my cpu was running at 2.8, and not the 3.2 that it says on the tin :wallbash:
    i checked the bus speed and its running at the right setting but still no 3.2 :waah:
    any ideas guys (plz keep replys simple like me)
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Might be worth whipping the cooler off and seeing what it says on the chip.
    Also, try downloading CPU-Z as well, that might show you if in fact it is a 2.8 rather than a 3.2
  3. JoKeR
    23 Apr 2004
    it came boxed and sealed as a 3.2, it also says in my computer properties that its 3.2 and its running at 2.8 :sigh:
    i think im gonna cry :waah:
  4. Ben
    Ben What's a Dremel?
    11 Aug 2003
    Cpu-z
    + what Highland3r said
  5. JoKeR
    23 Apr 2004
    Highlander just installed that CPU-Z program and it says the same thing
    CPU:p4 3.2
    FSB:200.5Mhz
    Bus Speed:800.5Mhz
    = Core Speed 2806.9Mhz
  6. dom_
    dom_ --->
    4 Jan 2004
    tried reseting you bios?
  7. JoKeR
    23 Apr 2004
    never done that b4 could you please explain how, sorry that i ask
    but im still learning and could do with a push in the right direction :duh:
  8. Guest-16
    Guest-16 Guest
    update the bios, resetting it wont do FA. Goto the Abit site and follow their instructions.
  9. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    Can't you just change the multi in the BIOS to the right setting for 3.2GHz?
  10. JoKeR
    23 Apr 2004
    Tom it is set for 3.2 m8.thx anyhooo
    just had look at how up date the BIOS and if i wasnt confused earlier i am now, think ill need to get a pro in. thanks Bindi
  11. Tomm
    12 Apr 2004
    Never used it, but for flashing the BIOS try winflash :thumb:
  12. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Woo! Lower multiplier forced on a 3.2. Overclocker's dream TBH, get some decent RAM and clock that sucker :D
  13. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    If its a presscott chip some older bioses actualy overide the mult on presscotts. Go to abit website and download the newer bios for your mb if you wana just run at 3.2. But you may be able to control the bios to 18mult in your bios if your lucky.
    I heard of this hapening. Dont worry about it. Resrch the Abit forums and they will help you there the comunity is gr8 there.
  14. unclean
    unclean SMP obsessive
    30 Dec 2003
    Yeah, I'll take it off your hands :baby:
  15. JoKeR
    23 Apr 2004
    Thx a load Jag :thumb:
    went to the Abit forum a found a link to a program that auto updates and installs the new bios for Abit boards, :D took all of 30secs and a reboot :rock: got my 3.2 woohoo :rock:
    I love Abit there nub friendly, here's the link for my fellow nubs :naughty:
    http://www.abit-usa.com/downloads/bios/flashmenu.php
