Modding Painting a Case
Discussion in 'Modding' started by Ronin, 9 Nov 2003.
  1. Ronin
    Ronin What's a Dremel?
    26 Sep 2002
    I'm a noob and I would like to know the steps on how to paint a case I would like to know how to do the Chameleon Paint. I was thinkin of midnight blue, black and purple. I was gonna do a flat black in the inside to absorb the uv lights. :wallbash:
    Please Help.
    :dremel: :duh: :wallbash:
  2. kingkobra
    kingkobra What's a Dremel?
    18 Jan 2003
    Autozone now sells kits in can form to do chameleon paint. Check there, if there is one nearby.
  3. Ronin
    26 Sep 2002
    Thanx!!
    Hey I'm originally from Roanoke VA not to far from you. I live in DC now though but i go home often. :jawdrop:
  4. Bluebark
    Bluebark What's a Dremel?
    1 Sep 2003
    Welcome to the threads…The paint scheme you refer to is called Flip-Flop and was designed for objects with round surfaces like…cars. It’s not really made for flat surfaced computer panels. While you can still get the flip-flop effect off the panel, it requires you to walk around the case until you find a light source to reflect off of. Not really something I would want to do. I guess you could hang a lot of pin spot lights around the case to highlight the paint job.
  5. Ronin
    26 Sep 2002
    Thanx dude!
    I think im gonna go with the basic Midnight blue then . Do you know what tools I will need to do all the stuff just for painting.
  6. Phlek
    Phlek What's a Dremel?
    25 Aug 2003
  7. Bluebark
    1 Sep 2003
    What type of paint do you plan on using?
  8. Ronin
    26 Sep 2002
    Paint
    I'm gonna use regular Spray Paint. I have decieded not to do the chameleon paintjust gonna focus on 1paint for now since it is my first modding job.
    For all the Star Wars Geeks: :rock:
    Well my theme is gonna be Jedi with the Rebel alliance as the windows and the Jedi knight as the pic.
    The case is a simple generic case. im gonna paint the outside with midnight blue. inside is gonna be flat black w/ uv active stars (very small stars)
    top window will be oval shaped with a fan in the middle.
  9. Ronin
    26 Sep 2002
    Anyone
    If anyone can help me customize it even more please respond!
    :dremel:
  10. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
  11. Bluebark
    1 Sep 2003
    What I meant was, are you going to use lacquer or enamel? I read Linear’s guide to painting and it’s pretty good. I don’t really approve of spray bomb painting but I can understand the cost value of using it and if you work at it you can get almost the same results as using a gun. You don’t usually clear coat pastels…that’s mainly for reserved for metallic. But a clear coat will give you the wet look if that the finish you want to achieve. Let me ask you two questions…Do you plan on doing a lot of painting and do you have access to a compressor?
  12. Ronin
    26 Sep 2002
    Hmmm...
    Well this is my first mod job and also my first paint job. I wanna do something simple do i want it to look good. My Father-in-law is gonna buy a dremel. and he will also help me.
    I just gonna do a simple midnight blue but i want it to shine.
  13. Bluebark
    1 Sep 2003
    Then start off learning to use a spray bomb and you can either use enamel or lacquer as a base for your color coat and the use a polyurethane for the clear coat. My strongest recommendation is to spend a few bucks and practice the technique that Linear describes in his tutorial on an old case. The extra time you spend up front will pay off in the back end. Let me know when you decide on the type of paint your going to use and I will give you some help if you want it. There is a difference in the way you apply the two basic types of paint.
  14. Ronin
    26 Sep 2002
    Thanx dude!
    I will start practice this week i will know the paint prob 2morrow
  15. Ronin
    26 Sep 2002
    heh
    :eyebrow: :clap: :jawdrop: :thumb: :dremel: :wallbash:
    ::::BUMP::::
  16. Bluebark
    1 Sep 2003
    Is there something your trying to say?
  17. Ronin
    26 Sep 2002
    Ummm....
    Anymore suggestions on what kinda of paint works best on cases? :dremel:
  18. Visualaid
    Visualaid What's a Dremel?
    15 Apr 2003
    car spray paint
    primer, colour, clear coat
  19. Bluebark
    1 Sep 2003
    My suggestion depends on you’re painting environment…Where you going to paint the stuff?
  20. Ronin
    26 Sep 2002
