CPU Please check my 3570k benchmarks and temps
Discussion in 'Hardware' started by Admiral Huddy, 13 Aug 2012.
  1. Admiral Huddy
    Admiral Huddy What's a Dremel?
    16 Jul 2009
    Stock settings,
    I7 3570k (custom water cooled)
    Gigabyte Z77X-UD3H Intel Z77
    Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit
    Gigabyte GeForce GTX 670 Windforce 3X 2048MB
    These seem a little under your review postings
    Again these are under.
    Temps:
    Again temps seem a little disappointing.
    Thanks for your input.
  2. rollo
    rollo Modder
    16 May 2008
    They use a fully reformatted disk hence score slightly more points unless you ran these benchmarks on a totally clean system you are not really comparing the same things.
  3. Admiral Huddy
    16 Jul 2009
    I see.
    Ran same day as a fresh install of Windows 7.. OS is on a dedicated SSD partition.
  4. aNuclearPidgeon
    aNuclearPidgeon Minimodder
    3 Mar 2011
    Try and lower your voltage a bit. My 3770K can easily achieve 4.2GHz at 1.152v with lower temeperatures.
  5. xPinky
    xPinky What's a Dremel?
    2 Dec 2011
    I think your voltage could definitely go lower, I am running at 4.5GHz with an H80 cooler at similar voltages (1.246V)
  6. Admiral Huddy
    16 Jul 2009
    VCore shows as 1.188, VID shows as 1.24. This is stock settings?
  7. aNuclearPidgeon
    3 Mar 2011
    If your BIOS settings show that your voltage is set on auto then yes. If thats the case ttry lowering it manually.
  8. Admiral Huddy
    16 Jul 2009
    So changing the Vcore < 1.1188 for stock?
  9. aNuclearPidgeon
    3 Mar 2011
    Try 1.1V for stock.
  10. Admiral Huddy
    16 Jul 2009
    cheers buddy. Will do.
    Also, i'm slightly concerned as to why the CustomPC overclocking guide for the 3570k suggest a 1.4v change for 4.8GHz.. That's quite a leap no?
