Needs deleting - as do all of my Threads
Discussion in 'Hardware' started by Guest-44638, 19 May 2020.
  1. Guest-44638
    Guest-44638 Guest
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    There's no requirement, just your use case. Your 3600 is perfectly suited for what I assume is your use case (games) and I'd personally hold onto it until the next full sets of hardware come around (AM5 or real 10nm Intel, DDR5, maybe PCIe 5 though that's probably ways off on personal computing).
  3. silk186
    silk186 Derp
    1 Dec 2014
    There is never a need, only a want and a budget.
    adidan likes this.
  4. GeorgeStorm
    16 Dec 2008
    If you do stuff that likes more cores, then you have a reason to get more cores, where exactly that ends up on the i3/5/7 etc scale is just marketing.
  5. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    Of course not, let’s face it, there are plenty of people in London that have super cars...
    Generally it’s a matter of balancing what you need, trying to add some extra to allow for future-proofing, and what you can afford.
  6. GeorgeStorm
    16 Dec 2008
    Unless you're running something 100% 24/7 I don't think it needs to be a consideration, i3/5/7/9 etc aren't designed for different/specific tasks other than in the fact ones with more cores will perform better at tasks than can utilise more cores etc.
    Nothing wrong with having a 24 core cpu and only run things that use a single core, it's up to the user in the end.
    Until Christmas the 4 most powerful cpus I owned were ones that spent 99% of their time unused not even in a board, same with gpus. I've decided to use some more now, but still my most powerful cpu is sat in its clamshell on a desk just chilling.
    I never felt the need to upgrade so didn't bother.
  7. David
    7 Apr 2009
    Ryzen 5 & 7 are the same architecture - Ryzen 7 will have two CCXs and Ryzen 5 either has 1 and a half or two CCXs each with a core fused off ( I can't remember). The efficiency is more or less the same - IPC difference will be negligible.
  8. wyx087
    15 Aug 2007
    I like to look at it this way.
    You spend more to be on the cutting edge (eg. i7/i9), then if you are okay with performance, you won't need to upgrade as often to keep up.
    For example, I have i7 2700k. When overclocked, it can be quicker than i5 7500. Meaning I didn't need to upgrade to play HL Alyx. Whereas if I had an i5 2400, its multicore performance may not be able to work with latest multi-core games.
    Arboreal likes this.
  9. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    'Tiers', or 'i5/i7/ryzen5/ryzen7' are pure marketing ****. Ignore it entirely, as it tells you naff-all about actual performance.
    Instead, decide what you're going to be using it for (gaming? photoshop? 3DCG rendering?) and look for benchmarks in those applications to see which one actually does the job you need it to do best for your budget.
  10. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Or what your wants are. I want, for instannce, 5GHz and a LGA socket on my next build, so it's unlikely to be a Ryzen chip.
  11. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    I'd wait 4 months to execute that idea ;)
  12. Bloody_Pete
    11 Aug 2008
    Oooh, why is that?
  13. MLyons
    3 Mar 2017
    Ryzen 4XXX is pretty nutty.
    Bloody_Pete likes this.
  14. Bloody_Pete
    11 Aug 2008
    But is it LGA? :p
  15. MLyons
    3 Mar 2017
    But is it better :p
  16. Bloody_Pete
    11 Aug 2008
    Its a preference I have :p Personally I've had to bend back pins on a PGA CPU, but never on a LGA motherboard :p And the socket retention is VASTLY better!
    MLyons likes this.
  17. MLyons
    3 Mar 2017
    Intel stuff does seem to "just work" more than AMD stuff. I'll give you that.
  18. Bloody_Pete
    11 Aug 2008
    Apart from XMP, I've never managed to get that to work!
  19. edzieba
    14 Jan 2009
    Huh, I've yet to have a board where I went to enable XMP and have not found that it was already on.
  20. Bloody_Pete
    11 Aug 2008
    AMD have their own version, but it does the same thing.
