Project: DarkBlueCreations
Discussion in 'Project Logs' started by amesterdamer, 28 Jul 2004.
  1. khendar
    khendar What's a Dremel?
    25 May 2004
    We call it a Stanley Knife down here. But Stanley is a brand so thats not technically correct...
    Nice work. Seems a lot of people are using that drill method for cutting holes...might have to give it a go until i get my jigsaw/dremel.
  2. amesterdamer
    amesterdamer What's a Dremel?
    2 Jun 2004
    Part 4.1 Led's, Button & Switch
    I need to make my own buttons, I was thinking in using some led's to light then up... so I used this simple connection.
    I used some ideas from this "how-to" - http://forums.bit-tech.net/printthread.php?threadid=32590
    http://pwp.netcabo.pt/0144621501/projecto/leds2.jpg
    [Sorry aboute this next pictures, the quality is a disgrace :wallbash: but it's possible to see the essencial ideas...]
    I started to make my own buttons of spare acrilic
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_3.jpg
    Then i decided were to put the buttons
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_4.jpg
    got to open it up :dremel:
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_5.jpg
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_6.jpg
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_66.jpg
    In the case I also had to open some holes :dremel:
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_7.jpg
    the acrilic also need some spare space to put the led's into place
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_12.jpg
    the aluminium holes for the bottons
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_13.jpg
    Here I drilled the center of the button in order to put in the switch
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_10.jpg
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_11.jpg
  3. amesterdamer
    2 Jun 2004
    Part 4.2 Led's, Button & Switch
    to put the bottons into place, I used some spare aluminium and I built a support for the switch
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_14.jpg
    switch in place... (****ty photo :S)
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_16.jpg
    this was the first time I also worked with led's...
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_17.jpg
    done..
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_18.jpg
    putting the led's in the right position...
    http://pwp.netcabo.pt/0144621501/projecto/fotos/2_19.jpg
    the 2 led's in position
    http://pwp.netcabo.pt/0144621501/projecto/fotos/digi1.jpg
    the support for switch
    http://pwp.netcabo.pt/0144621501/projecto/fotos/digi3.jpg
    here it's possible to see the spare acrilic that I used to put the led at the right position
    http://pwp.netcabo.pt/0144621501/projecto/fotos/digi2.jpg
    Testing!!!!
    not bad for the first try with this :clap:
  4. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    it is comunly called "exatco knife", and the other thing is called a file in english
    looks very keep it up
  5. amesterdamer
    2 Jun 2004
    in portugal we call it "X-Acto" ;) almost the same thing
  6. ¿þŘΩĐĮĢΫ?
    13 Jun 2004
  7. amesterdamer
    2 Jun 2004
    is this page to heavy with all this pictures?.. should I post the url for the images? ... :S
    It's a compilation of the original post, that's why it has a lot of pic per page :S
    EDIT: Done... changed [​IMG]
  8. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    It's called a utility knife. At least that's what it's called in the US of A.
    Oh and an X-acto knife is something different.
    Oh and very nice mod!
  9. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    Nice job... - it looks great!
    Just to answer your questions...
    yup, perfect :D
    Lima = file
    The yellow thing is called a "stanley knife"
  10. amesterdamer
    2 Jun 2004
    Part 4.3 From of the case
    I'm making my site, later i'll post more pic's
    [[]] :thumb:
  11. Miirk
    Miirk What's a Dremel?
    26 Jul 2004
    This is a beatiful case!
    The stealthed drive-cages are really nice.. :thumb:
  12. R@Mo
    R@Mo What's a Dremel?
    14 May 2004
    Can't believe you get such nice cuts after using that method. Must have taken forever to file down the edges, but they look damn nice! :rock:
  13. Nova Kain
    Nova Kain What's a Dremel?
    23 Apr 2004
    I love the sleak look you've created with the aluminum!!
  14. amesterdamer
    2 Jun 2004
    Well I needed something to protect de fan... or maybe the fingers! ehheeh so I started to draw some ideas
    first I draw this
    but this design didn't help with the airflow, so back to work
    and in the side of the case i'll put the
