Scratch Build – In Progress Project: Infinity - Planning
Discussion in 'Project Logs' started by DoOb's, 31 Aug 2007.
  1. DoOb's
    DoOb's Overclocker/Modder
    7 May 2007
    Hey guys, Ok so let me just get to it. Custom built case from scratch. Materials: Aluminum and Perspex.
    System Specs:
    Intel Core 2 Duo E6420
    DFI Infinity P965 - S
    Gigabyte 8800GTS 320MB
    Crucial BallistiX Tracers PC 8500 (LED)
    WB 120gig IDE 8mb ---- WANT SATA
    Maxtor 160gig IDE 8mb --- WANT SATA
    Asus DVD-RW 18X SATA
    Watercooling
    Asetek Antarctica CPU Block
    Asetek Chipset Block
    Coolwave Dual 120mm Radiator
    Asetek Res
    1000l/hr or so pump dnt know
    all 10mm diameter.
    OK The Planning So Far:
    Front View
    Top View
    Back side View
    Side Panel View
    Side Panel view 2
    Side Frontish View
    Ok so thats my Design so far, windows and all that will be designed on Paper. then i'll show you those a bit later.
    I'm gonna try much aswell at getting sponsors.
    WardKiss
    Durban Plastics
    AluminumCity
    Those are the main ones for now i wanna try and get some type of discount or FREEness
    Thats all for now
    DoOb's:thumb:
  2. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    have you done any other mods? as you will not get any sponsors unless you have either done other mods or done quite a lot of the main work on this one.
    and also havve you even read the rules???? i think number 2 is that you are not supposed to post in the project logs section untill you have actually started modding.
  3. DoOb's
    7 May 2007
  4. ComputerKing
    8 Sep 2006
    Nice Ideas Really! I can't wait to see the action. Amazing! Well done.
    Good luck.
  5. dacust
    dacust What's a Dremel?
    10 Mar 2007
    They don't have to close it, they can just move it to the Modding thread and move it back when it qualifies. But if you get some actual work posts in pretty quickly they probnably won't bother.
    Your previous mods don't have to be in this forum for prospective sponsors to get an idea of what you do.
    I like the separate compartment for the WC stuff. Looks like a promising design. Keep it up!
  6. DoOb's
    7 May 2007
    Thanks Dacust, yea gonna get on it A.S.A.P just sourcing Alli and then im on my way.
    I'm gonna do a model out of corra cardboard, so i can get all the right sizes, then i will start then real case. That way i have better way of solving solutions before they happen in my real case and wont make mistakes that could arise.
  7. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    This coulde be interesting. I like your design.
  8. DoOb's
    7 May 2007
    Thanks NZ_mod_man
    Ok so i phoned the Aluminium place earlier, and they sell big sheets for a decent price, a price where you can make a case. And they can also do cut cuts. Which is what i need to have a accurate nice looking chassis, with no crappy edges.
    Also done some measuring up.
    Length of the case will be just about 56cm long, 42cm in Height and 30cm in width. No bad i rate. Length for this is a must becoz of pump and res being in the compartment together. Should wourk out pretty well.
  9. Guest-23315
    Guest-23315 Guest
  10. DoOb's
    7 May 2007
    What my pc is looking like now, lol
  11. Guest-23315
    Guest-23315 Guest
    I've heard many-a-bad-thing about those Waterchill connectors. How are they holding up?
  12. ComputerKing
    8 Sep 2006
    WOW! This is so so sos nice! The water cooling is amazing!!! WOWOW, This is kickass, Can't wait to see the mod!
    Good luck.
  13. DoOb's
    7 May 2007
    Well the connector did leak but that one you see there is a new one i bought. Works very well, no leaks and high performance, got it from here, with 5 10mm barbs aswell
    http://www.generalpneumatics.co.za/awdep.asp-dealer=5766&depnum=9952.htm
    Thanks Computerking, yea its going to be fun for sure
  14. DoOb's
    7 May 2007
    Ok here are the pics, a whole new look and my feel is right on this one completely now.
    Ok here were are. Written type on them so no need to explain.
    Um as for Power Switches and Reset and Cmos CLR im gonna try go remote instead. Remote control.
    Hope you guys love this one, coz im feeling this one.
