Project: L-Comp
Discussion in 'Project Logs' started by stogusmaximus, 5 Mar 2004.
  1. stogusmaximus
    stogusmaximus What's a Dremel?
    24 Jan 2004
    I have a new design in mind for my next case. It is L shaped. I have decided to do this so that I can fit my case in the corner of my desk, and not worry about leaving room in back for cables, and air flow.
    Will start building in the next several days.
  2. SJH
    SJH Minimodder
    24 Dec 2003
    That's actually such a good idea I don't know why I haven't seen it being done before.
    I like how you can see the internals of the case through the window through the 'front' of the case.
    Looking forward to this :)
  3. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Looks good...
    Some sugestions...
    The fans that are in the "front most" part of the L will not be possible if there are cdroms there.
    You may want more room for the PCI slots, expecially for a window and some extra tall pci, agp cards and to allow for more airflow around the top.
    What is the case going to be made out of?
    Looks good... *Suscribed*
  4. stogusmaximus
    24 Jan 2004
    Sugestions noted.
    I was planning on making it out of plywood.
  5. Oracle
    Oracle What's a Dremel?
    7 Feb 2004
    mabeuy
    Mabey you could instead of a L put a U so that you could have show the iners and then mabbey have like dual drives and crap like that then mabey a LED display :naughty: any ways looks goodliike the L desing also
  6. stogusmaximus
    24 Jan 2004
    Measurements.
    I am planning on using plywood for the "skin" and re-enforcing the joints with 1x1.
    Stogus
  7. Go4t
    Go4t i
    13 Dec 2003
    that looks cool i think that would be better than my case for where i have to put it right now :dremel: :rock:
  8. coorz
    coorz Miffed
    25 Apr 2003
    That's really an original and very practical mod. Looking forward to this one!
  9. KONIJN
    KONIJN What's a Dremel?
    30 Nov 2003
    this is a nice idea
    want to see how it works out
  10. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    Yeah thats a really good idea, I need to do something like that. [OT]Is there a possibiltiy that some company makes a case with the mobo tray on the other side?[/OT]
    I'm gonna stay tuned to see how this progresses. Hope this turns out to be a gd mod
  11. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    This certainly looks interesting... I think I am going to subscribe to this, to see how it turns out. I have some ideas for a custom computer myself... I am not going to say what however; This is something I want to keep secret. Good luck on the L-compy! :thumb:
  12. planki
    planki ...
    20 Dec 2003
    now that is a unique idea if i ever did see one
  13. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    looks good so far, but this concept absolutely screams "sketchup me!" - you'll be able to fully model the case...
  14. Vo0Ds
    Vo0Ds Fake potato
    6 Feb 2004
    Kewl, first think like that ive seen, should look madd!
  15. Deep-Blue
    Deep-Blue Part-time Overclocker
    1 Feb 2004
    Its a pretty cool idea, tho not unique. It expands on this:
    http://www.xcase.co.uk/acatalog/_I_TEE_CASES_.html
    Still, the idea with the window greatly improves the overall feel, and i think the case would have some interesting thermal areas as items such as HDDs and GFX cards would be kept seperate.
    DeeBee
  16. KONIJN
    30 Nov 2003
    those are ugly this one would look better
  17. clocker
    clocker Shovel Ready
    21 Dec 2003
    I have been fooling around with designs for my own custom case for a while now with only mixed results.
    Your concept solves many of the problems that I faced.
    Consider your idea stolen. :thumb:
  18. stogusmaximus
    24 Jan 2004
    Can't wait to see your execution of this design.
  19. stogusmaximus
    24 Jan 2004
    Project put on hold for short time.
    I am in the process of changing jobs, and I will now be working out of the house. :rock: :rock: :rock:
    All the funds that I had set aside to build my L-Comp will now be channeled into purchasing a laptop and the gear I need to work from home.
    Not Cancelled, just Postponed.
  20. DaRkPhAsE
    DaRkPhAsE What's a Dremel?
    27 Sep 2002
    Shame it had to go on hold but priorities etc.... was looking forward to this one. will watch for it's return. good luck sourcing all you need. :rock:
    I had one of these in black from the original creator when he was testing the water and selling a few on ebay. An absolute Mare to work on, really cramped, room for 2x 60mm fans on the side (cutouts for 80's but only 10mm deep one's would fit!) easy access but dire wire management capability. Used to have a full picture by picture dismantle an rebuild but i think I have lost them now
    soz for the slight hijack..
    DP
