Project Matrix
Discussion in 'Project Logs' started by Reg Shoe, 15 Apr 2004.
  1. Reg Shoe
    Reg Shoe What's a Dremel?
    24 Apr 2003
    This is a project I wanted to start a long time ago, but posted this only now cuz today I got my HP 945.. :clap:
    The goal of this project is making a "matrixish" case, which will include the following things:
    Black plexy window, with matrix "letters" engraved or milled in. I'm not sure if I'll light it with green leds, or paint with a green UV gel inside the letters. Got to test it and see which will be better.
    Stealthed DVD and CD-RW.
    Motorized LCD coming out of the drive bay.
    Inverted LCD (black BG, green font).
    All cables sleeved in UV green.
    All fans (2x120,2x80) UV green.
    UV cold cathode :p
    Fan controller (probably side windowed or in an outside box)
    These are the things from the top of my head right now, more will probably come later. You are more then welcome to suggest more.
    Things done so far:
    Install UV cold cathode.
    Install 2x120mm UV green fans.
    Sleeved fan tails.
    For now I have no Dremel around :wallbash:, so all the dremelish stuff will come later on.
    Pictures for your mind:
    Front of my case:
    Side of my case:
    Case opened:
    My lovely Zalman (forgot the model name):
    I hate this upload thingey.. well, when I'll finish uploading more pics I'll post them.
  2. ohcyt
    ohcyt What's a Dremel?
    7 Jan 2004
    [edit]I'm sorry but your links are quite dead "the page cannot be displayed" or st like that... I suggest using www.uploadit.org[/edit]
    fixed =)
    good luck with the Matrix theme, could be very nice if you do it right (worthless prediction that is lol)
    that Zalman is a CNPS7000(A)-Cu btw ;)
  3. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    takes me to hp login screen lol :baby:
  4. STellY
    STellY What's a Dremel?
    24 Aug 2003
  5. Twitch
    Twitch What's a Dremel?
    13 Mar 2004
    I love that case, how long did it take you to sketch that all anyway?
  6. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    Are those green fans the 120s you talked about?
    If so, how are they noise-wise?
    I was looking at getting a pair for a green/black HTPC I wanted to build, so I was wondering about them and where to get a good set.
    Oh, and definitely wrangle them cables :thumb:
    Maybe if you're feeling particularly swank you could try and changover all the molex connectors to UV green too?
    And make some of the wires of the PSU UV green as well?
    I'm spewing with "too much trouble for what it is" ideas haha
  7. Reg Shoe
    24 Apr 2003
    Yes, these are the 120mm fans. They are VERY noisey. That is the main reason why I am making a fan controller. If you are still intrested, they were bought at jab-tech.com at a pretty low price.
    At first, I wanted to change the molexes too, but it came to me that it is too expensive and not THAT visible..
    And about the PSU cables, they are to be sleeved too.
  8. naelq
    naelq What's a Dremel?
    14 Oct 2003
    another Israeli modder! :D :clap:
    good work bud! :thumb:
    PS, tell me Reg Shoe, is this a CopuCASE CI-6A19 case?! i'm thinking of buying one, is it any good?! & as we say: בהצלחה! :rock:
  9. Reg Shoe
    24 Apr 2003
    It's always great to see Israeli modders out there in the world. :p
    Yes, this is Compucase CI-6A19, but I recommend you on getting the CI-6919. It's 80NIS more, but it's about 10cm taller. In this case, I have no room for LCD and more goodies (except the drive bays..). So, it's you call, but I recommend the 6919.
    And now, some more pictures I took recently:
    Closeup on the rear 120 fan:
    Closeup on the front 120 fan:
    Cathode off:
    Cathode on:
    Thats all folks!
  10. naelq
    14 Oct 2003
    i'm not looking for a big case, since i have another cheiftech dragon one! :D i looking at this case because of it's 2x120mm FANS! :thumb:
  11. Reg Shoe
    24 Apr 2003
    Well, in that case, this is the case for you. It also comes with a nice 120mm fan with a temprature sensor.
    out.
  12. naelq
    14 Oct 2003
    is it noisey, is there enough room?! :rolleyes: (sorry for hacking your thread! :waah: )
  13. Providence
    Providence What's a Dremel?
    23 Jan 2004
    So...the cathode works. Congratulations.
  14. Reg Shoe
    24 Apr 2003
    There is enough room for everything. About the noise, I haven't tested that fan.
    Funny.
