Project Noobie
Discussion in 'Project Logs' started by wicked1, 19 Aug 2004.
  1. wicked1
    wicked1 What's a Dremel?
    19 Aug 2004
    Hey bit-tech forums just starting my first new case here is just a white chasis and getting ready for a paintjob on the rest of the case.
    [​IMG][/IMG]
    Heres a pic of the power supply in white
    [​IMG][/IMG]
    and mouse on primer
    and just a teaser shot the bottom piece of the chieftec
    [​IMG][/IMG]
    Ill update soon...
  2. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    welcome to the forum. just some tips: use only one set of {IMG} signs. and in the first post, tell us what you want to do in the project. what colors you will be useing and maybe even some scetches of how it might turn out, just to give us and yourself an idea.
    Good luck with your project, mate :)
    EDIT: hehe you edited when i was writing this.. great finish on that top panel! looking forward to see the rest!
  3. Clarkey
    Clarkey What's a Dremel?
    1 Jul 2001
    wow, the paint looks awesome, for a first timer thats fantastic
  4. wicked1
    19 Aug 2004
    thanks Im going with a white and orange look to the case nothing difficult just a lot of painting, had no real sketch to it but to figure what color I wanted and found it so thats really it thanks for the support.
  5. Litecore
    Litecore What's a Dremel?
    21 Sep 2003
    holy guacamole, that redish bottom piece is brutaly awesome! :rock:
    this case is gonna be so sweet when it's done. can't wait to see it then ;)
    what kinda paint did you use and what color is it exactly?
    and you should change the project name to "cherry cream" or something
    because of the colors used. i'm sure you can figure something out !
  6. Nova Kain
    Nova Kain What's a Dremel?
    23 Apr 2004
    I LOVE the gloss on that red paint!!! omg, it's beautifull !!
  7. Silverstrand
    Silverstrand What's a Dremel?
    29 Jun 2004
    Do you have a picture of the case before you started?
    Also, great mirror finish.
  8. wicked1
    19 Aug 2004
    Thanks the color is like a mix of copper with orange and yellow flakes and its automobile paint. Should be done with it soon thanks for the support. Yes the paintjob was done by me.
  9. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Holy crappole! :jawdrop:
    That's one of the best red paintjobs I've ever seen. It looks so darn good!
  10. Kverna
    Kverna What's a Dremel?
    6 Jun 2004
    Is that like a face or something ? :p
    Face in paint
  11. drinn
    drinn What's a Dremel?
    16 Jul 2004
    Weird paintjob :D
  12. ReFredzRate
    2 Sep 2002
    I think it's one of the best paint jobs. Ever. The face in the paint looks kind of funny, didn't see it before. However, the paintjob is so incredibly smooth. It's just too close to perfection.
    Will the entire case be red?
  13. wicked1
    19 Aug 2004
    LOL its not a face if you check under the chieftec dragon case you will see it to. Yes the whole case will be that same color.
  14. Kverna
    6 Jun 2004
    hehe.. the first i saw was "robin" from the batman movies :D
    With the mask and all !
    Ontopic: great paint job! did you wetsand between the coats ?
  15. lolzantz
    lolzantz What's a Dremel?
    9 Jul 2004
    wow
    wow that is some awesome paintwork man. what was your process to get it like that? its beautiful
  16. wicked1
    19 Aug 2004
    I sanded down to metal I had those pictures but for some reason my camera did not take them so once they were at metal I used alcohol to take out all the material than primed, wet sanded, primed again I went to deep for some reason so had to reprime then put the color, wet sanded , color again then added the yellow flakes, cant see the flakes Im going to get a pic of it and after the paint settled I clear coated it then buffered it after a day of the paint to fully set.
  17. lolzantz
    9 Jul 2004
    I have a coolermaster case and its all alluminum. Do i still need to sand prime and sand? When i touch the case it feels very smooth already since its alluminum.
  18. wicked1
    19 Aug 2004
    From what I know you sand it till you dont have a shiny look to it plus it also depends what paint your going to use on it.
  19. wicked1
    19 Aug 2004
    Alright another update heres the front panel of the chieftec with same color and has yellow flakes on it so hope you enjoy it and hope to get the case done soon.
    Heres a flash of the pic
    just a regular pic
    hope you can see the yellow flakes makes the paintjob color more wierd.
    Will update soon guys thanks.
  20. guy
    guy What's a Dremel?
    20 May 2004
    looks pretty good, looks glittery, maybe it's just the pic...
