Project Painstripper : Custom made Alu case
Discussion in 'Project Logs' started by Geqxon, 20 Apr 2005.
  1. Geqxon
    Geqxon What's a Dremel?
    16 Jan 2004
    Introduction
    Hi yall :)
    To introduce myself, I'm a 16yo student from the Netherlands. I've made 2 mods, where 1 isn't even finished. The first was a wooden case with graffiti painted on it, the second a metal drawer (which btw sucks to cut in :( ).
    Well, the one made of wood and spray painted with graffiti kind off sucks. It totally does NOT stand nice next to my pimpstation (ahum, my TV).
    Current situation
    From top to bottom, from left to right:
    -Stupid red siren which I already threw in the trashcan
    -Dual 16" subwoofers (true killers)
    -LED-Bar (show the latest news flashes)
    -2 smaller speakers (1 woofer and 1 tweeter each)
    -"Van Oranje" cap, Von Dutch ripoff :p
    -Loewe Credo 55 (Yes, that is 55cm aka 21-22 inch :waah: )
    -Former graffiti casemod, which is going to be chopped in pieces
    -Smaller speaker
    -Alarm clock
    -Technics V300 Mark II Amplifier
    -Akai VHS (which is going to be thrown away after I install a TV-card in my former Media PC aka this project)
    -Again a small speaker (tweeter style)
    -Keyboard
    -12 ports 10mbit Hub (3com, duh)
    -PS-Two + Controllers
    -Silver briefcase
    Future situation
    I am going to make a 19" black aluminium casing, which is going to have to looks of this baby:
    It’s going to be all black aluminium, LianLi style :)
    Post-update schedule
    21-4-2005: Post first sketch up design
    24-4-2005: Starting the base plate of this computer (MDF base plate)
    28-4-2005: Starting the aluminium casing
    30-4-2005 till 7-5-2005: Being in London :clap:
    8-5-2005: Making the finishing touch, like painting the Alu :)
    If anyone has suggestions what to do in London, please say so as where I have simply NO idea what I'm going to do there :p Tower of London maybe?
    PS: I've run this text through a spell-checker for over 3 times. If you still see spell-mistakes, please say so. There is nothing so nice as knowing what I'm doing wrong :)
  2. n0ll4k
    n0ll4k What's a Dremel?
    1 Jun 2003
    mhh sounds promising.
    but are you really going to paint the case or get it anonized?
  3. Geqxon
    16 Jan 2004
    I realy want the black aluminium look, like this:
    Will anonizing give that result? I now spraypainting a metal surface will give a mat black look, not the polisch alu look :p
  4. Variance
    Variance What's a Dremel?
    5 Mar 2005
    Yes, anodizing will get you the finish you're looking for. Pretty much all black HiFi equipment, including that Technics, have anodized finishes, giving them the unique finish and texture. Oh, and don't feel bad about your TV, mine is only 13"; my primary monitor is bigger than it (19"), haha. Good luck on this project.
    -=Kenneth=-
  5. Joungne
    Joungne What's a Dremel?
    11 Jul 2004
    If you're in London, pls dont forget to visit the TATE
    greetz,
    Joungne
  6. Geqxon
    16 Jan 2004
    Today I made some great process:
    And I instantly started building the "mainframe":
    I am still searching for ways to make alu black, andodizing is (I think) very expensive, and I dont know any shops in central-holland :)
  7. Geqxon
    16 Jan 2004
    Ok, so the design sucked. I made some great changes, and the case is now 12,3cm high instead of 19cm (4.82 inch instead of 7.6 inch). I can eventualy make it less high, because the wood I use as a baseplate is 1,8cm high (0.70 inch).
    Pictures will be posted 20.00 (GMT +1). I can't work tommorow, because I haven't bougth the wooden baseplate (and I am still at work, so I cant go out and buy some wood)
    And as you all know, the name of the case is kindoff gay. Its a mix of Paintstripper (because the previous case was painted with graffiti) and the heavy Pain in the ass my computer is giving me. If anyone happens to know a better name, please say so :)
  8. Geqxon
    16 Jan 2004
    Great news today! The sketch is finished :)
    The Current model closed (with actual measurments in centimeters)
    With the "hood" off. This is 1 whole piece, made in order to exterminate screws on the outside
    Exploded view, the front and back can me removed from the wooden baseplate.
    Topview with all the hardware installed (the hardware mounts aren't drawn yet)
    More great news: I found an andodize company about 16 kilometers (10 miles) from here! I hope he also does black, and that he isn't that expensive :p
  9. tsa cain
    tsa cain What's a Dremel?
    14 Mar 2005
    thats pretty cool keep up the good work
  10. Neo4
    Neo4 What's a Dremel?
    15 Oct 2004
    cool, keep working
  11. QuinnDexter
    QuinnDexter What's a Dremel?
    28 Feb 2005
    mm htpc..
    from your sketchup it looks like the optical drive isnt centered? is that just a bad angle or will the drive be mounted slightly to one side?
  12. kLLr
    kLLr What's a Dremel?
    11 Apr 2005
    Nederland rulez :rock:
    Relaxt project, waar in nederland woon je ergens?
    [english]Relaxed project, where in holland u live?[/english]
  13. Bluefan
    Bluefan test 123
    25 Feb 2005
    Nog aardig wat nederlanders hier. Mod ziet er wel strak uit, met welk programmaatje maak je die plaatjes?
  14. kLLr
    11 Apr 2005
    Maya? :idea:
  15. Geqxon
    16 Jan 2004
    Yes, I indeed live in the Netherlands (Amersfoort), but on an international forum, I'd rather speak the main-language, in this case English :)
    The CD-ROM is indeed not in the centre :( Putting it to the right will cause in making some collision with the PSU, putting it to the left will cause in making some collision with the PCI Cards :(
    Well, its the only Solution. I can somehow center it, but that will result in a casing of 19cm of height, instead of a casing with only 12cm of height
    By the way: I made this design in Sketchup 4 :)
