Modding Project - Sea Monkeys
Discussion in 'Modding' started by Don, 19 Nov 2003.
  1. Don
    Don Guest
    What im going to try and do is make a little home from some sea monkeys inside my pc. What are Sea Monkeys you ask, well there these little creature things that live in water "never" :p You can find more info about them here http://www.sea-monkeys.com/
    Here is a few pictures of them just so you get an idea.
    I was just going to make a little window in a blankin plate but i decided if im going to do it i might aswell do it proper so im going to make a acrilic box the same dimentions as a cd drive so i can just slide it into one of my spare bays.
    More info soon.
  2. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    could get a bayres and either block up or connect the 2 barbs together :)
  3. Don
    Don Guest
    lol i wish i had thought of that before i bought the perspects no worries tho i think using a bay res would solve a few problems i might have aswell.
    Thanks for the idea m8
  4. KinGvsKinG
    KinGvsKinG What's a Dremel?
    20 Apr 2003
    they're brine shrimp! i use to feed them to my sal****er fish. hmmmm, i might add some to my watercooling system.
  5. G-gnome
    G-gnome Peter Dickison
    8 May 2003
    Welcome to the forums Don.
    In accordance with forum rules in the 'Read BEFORE posting' sticky, plans and ideas for projects go in modding so I'll move it there.
    Once you have done some real, solid work on the project and posted work-in-progress pics email a staffmember and we'll move it back.
  6. Shogun
    Shogun Banned
    18 Jul 2002
    don where are you going to get these sea monkeys from?
  7. Dad
    Dad You talkin to me?
    15 Apr 2003
    Hmm. Me thinks the swear filter is quite sensative ;)
  8. Don
    Don Guest
    Woolworths in town sells some kits ranging from £10 to £30 but i know you can order them online from the sea monkey shops lol
    Also some pet shops stock em cos u fead em to salt water :p fish but them ones are usually frozen in blocks :p
  9. jezmck
    jezmck Minimodder
    25 Sep 2003
    it took me extreme measures to work out what that word was - I had to go to onelook to use the crossword function. (I thought it was something like salamander, me so stoopid).
  10. Don
    Don Guest
    lmfao
  11. chadwick
    chadwick What's a Dremel?
    2 Oct 2003
    not true..alot of places sell live brine shrimp as well as daphnia and bloodworm in packs. Brine shrimp tend to be more expensive...but remember they live in brine not water.
    and they are not specifically meant for sal****er fish...freshwater fish love live foods to
  12. Don
    Don Guest
    they can live in water long as u add the packet stuff u get with them which i guess is brine :p
  13. Bossman
    Bossman What's a Dremel?
    6 Nov 2003
    Interesting thread, how big are these sea monkey things?
  14. Don
    Don Guest
    If u buy a sea monkey set they start of the size of a pin prick n take a few days to grow, i think the bigest size they can be is an inch but they grow to there surroundings so big case big sea monkeys.
  15. DRxAndy
    DRxAndy What's a Dremel?
    6 Mar 2003
    for anyone interested, he said S-a-l-t - W-a-t-e-r :D
    interesting idea, but dont you have to keep a lamp on them?
  16. chadwick
    2 Oct 2003
    thats also a common misconception with normal fish..people believe they will only grow to the size of the tank which is incorrect they will continue to grow, maybe not at the same rate but to the same size. problems that can occur with fish in tanks not suitably sized are usually skeletally related..as far as they will get kinked tails etc.
  17. Don
    Don Guest
    im sure my blue neon will surfice im not expecting them to live very long anyways lol prehaps it was a bad idea
  18. Don
    Don Guest
    i just read that out of the manual lol, mebys its a con to get u to buy a bigger home
  19. MajicPhatCalves
    MajicPhatCalves What's a Dremel?
    17 Nov 2003
    My little sister has had sea monkeys for ages. The only ever grew to about 2-3mm long / 1 mm wide.
    To be honest, I never saw the appeal.. :)
  20. Fr0z3n
    Fr0z3n What's a Dremel?
    21 Oct 2003
    What would be cool is if you could stick a UV light up to them and they glowed. :D
