Project Stainless
Discussion in 'Project Logs' started by microsoftman, 22 Feb 2004.
Thread Status:
Not open for further replies.
  1. microsoftman
    microsoftman Banned
    20 Feb 2004
    Well, here is my new project - a stainless steel case. The basic concept is to bring back flames, and also to create a cooler looking case (not exactly a box). You will see, I will just post the pics, you can ask questions about them later.
    this is the left side with the flames behind where the plexi will go
    here is all the metal together before being bent
    here is just the bottom and back of the case bent
    the beginning stages of bending the case into shape
    this one with both sides bent up
    So, tell me what you think, there is still much work to do here (welding, frame, and alot of stuff that i'm keeping secret for now).
  2. Morphine
    Morphine weeee!
    23 Feb 2002
    add an "http://" before each of the URLs for the pics.
  3. naelq
    naelq What's a Dremel?
    14 Oct 2003
  4. Tau
    Tau Sharingan!
    17 Nov 2002
    Nice, the flame cut-outs look pretty cool
  5. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    VERY nice .
    i'm a little curious aboutt he back panel and how you are planning to secure the pci / agp cards.
    Considering that there is no raised section for them to screw into.
  6. microsoftman
    microsoftman Banned
    20 Feb 2004
    That IS a good question that I have pondered many times. Basically, I think that I will bend the PCI cards so that they can work pretty much flat with the back of the case. It was an oversight of mine to cut the square there rather than a ] shaped line which I could bend over and screw the cards into. :duh: But I think I will like it more this way anyway.
  7. SharkBait
    SharkBait What's a Dremel?
    3 Dec 2002
    Very nice start! I'm looking forward to seeing how this one turns out!
  8. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    How about scraping and attaching just that portion of backboard from another case. The Inwin A500 comes to mind as viable canidate.
  9. Altron
    Altron Minimodder
    12 Dec 2002
  10. macroman
    macroman The One
    3 Sep 2001
  11. microsoftman
    microsoftman Banned
    20 Feb 2004
    I don't see what the big deal is. It isn't a conspiracy, more important to me seems to be: WHAT DO YOU THINK ABOUT TEH CASE?!? :eyebrow:
    I will be starting the frame soon, probably have it done in the next week and then it'll be time to paint the frame and make drive cages. I have some ideas for the drive cages that I think will look pretty cool. If any of you want to explain to me how to make an LED bus which could power about 20 leds that'd be cool. They will all be in about the same place so that's why I wanna make a central powering unit. Thanks.
  12. DreamModder!
    DreamModder! What's a Dremel?
    26 Jan 2004
    greeeeeeeeee I like it!
    keep it up good work! :thumb:
  13. The Spyder
    The Spyder What's a Dremel?
    27 Apr 2003
    and its dead again........
  14. xrain
    xrain Minimodder
    26 Jan 2004
    dude thats tight, me wants one :lol: thats some great work you got there *presses the suscribe button* those are some awsome flames tho! cant wait to see more!!!!!!!!!! :rock: keep up the awsome work!
    --xrain--
    ps- sorry for the confution!
  15. Wowza
    Wowza Banned
    23 Feb 2004
    Thanks alot for subscribing dude. Don't tell anyone, but I am microsoftman - lol. Hopefully they won't ban me again, as I have not done anything wrong, but who knows. But anyway, what did you mean "those are some bad flames tho!" - you don't like them? Suggestions?
  16. xrain
    xrain Minimodder
    26 Jan 2004
    sorry il fix that i meant they were the best flames iv ever seen! :D i like how your not going for the metal box look i like the different lines keep up the awsome work!!!!
  17. Wowza
    Wowza Banned
    23 Feb 2004
    well, thanks! I'm gonna be doing a lot of stuff here with this, so I am glad that you like the basic shape... hopefully it will only get better from this point on. Here is the basic list of things I need to do:
    1. Weld and Mount Frame
    2. Cut Plexi for Window
    3. Weld/Permanently afix the shell into its proper position
    4. mobo tray
    5. drive cages
    6. lights (leds and cc's)
  18. xrain
    xrain Minimodder
    26 Jan 2004
    sounds fun :D :clap:
  19. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    like the idea behind a custom case, but i really dont care for the shape... admire you for doing it your way hope it works out for ya
  20. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    Sorry if people like this project, however Ionpcs/Microsoftman/Wowza is repeatedly signing up with multiple accounts and ignoring our rules (his own words) on negating bans etc.
    This project thread is closed and (should you be reading this as a guest Ionpcs) if you wish to show people your project, I suggest you set up your own website where you may behave however you like.
Thread Status:
