Modding Project Tech Warlock
Discussion in 'Modding' started by PlagueH4, 20 Aug 2004.
  1. PlagueH4
    PlagueH4 What's a Dremel?
    20 Aug 2004
    This is my first mod. It's just basic moding for now. I'm thinking of something original.
    System spec.:
    Procesor: AMD AthlonXP 2500+ Barton
    Mainboard: Abit NF7
    Graphics: Chaintec GeForce Ti4200, 8xAGP
    Sound: SB Audigy 2 ZS
    Ram: PQI 768 Mb (Planing to change that)
    Power supply: Q-Tec 550W Dual Fan Gold
    HDD: 1xWestern Digital 80Gb, 1x Western Digital 120Gb (Both with 8Mb cash)
    Teac CD-RW, Lite-on DVD-RW
  2. PlagueH4
    20 Aug 2004
    And a lame question :D How can I atach pics?
  3. ajack
    ajack rox
    17 Apr 2003
    (img)http://location.of.image(/img)
    Replace brackets with square brackets.
    Or alternatively, click the little yellow picture icon when you're writing the post and put the location of the image there.
  4. -N4cR-Stigma2K
    -N4cR-Stigma2K Banned
    8 Jul 2004
    Then you will have to get a server or a webpage/homepage that can host your pictures. If you are interested you can borrow my webpage, and upload the pictures from there.
  5. PlagueH4
    20 Aug 2004
    Ok, let's say I've got it.
    This is what I started with:
  6. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Interesting case... so what are you planning for it now...?
  7. drinn
    drinn What's a Dremel?
    16 Jul 2004
    Omg.. I think that Satan likes this case.. when it's ready.. :D
  8. PlagueH4
    20 Aug 2004
    Ok, It's working. Thanks guys.
    Here's what I did: painting, installed some fans, windows from both sides, some engraving, atached wheels, green neon light under it, dragon label on one side (I'm planing to remove it, cause it's discordant to the view), removable skull on the top.
    Here's some pics:
    That's it for now.
  9. G-gnome
    G-gnome Peter Dickison
    8 May 2003
    Moved to modding in accordance with the Rules for Project Logs.
    Finished mods belong in modding. For a finished mod to count as a project log, a modder must have a documented and photographed log of most of the stages of construction showing work in progress, etc.
    Please re-size your huge pics also, maximum of 600 pix wide, though 400x300 is preferred - I'll change them to urls in the meantime.
  10. TMM
    TMM Modder
    12 Jan 2004
    the window cut looks smooth! gj
    Now how about painting/stealthing the cd drives :dremel:
  11. PlagueH4
    20 Aug 2004
    I'm working on that.
  12. Nova Kain
    Nova Kain What's a Dremel?
    23 Apr 2004
    Is there any story behind the skeleton head? or is it just fluff -n- stuff
  13. Slayer the Unholy
    Slayer the Unholy What's a Dremel?
    19 Aug 2004
  14. PlagueH4
    20 Aug 2004
    this is a souvenir from my uncle from his travels around the world.
  15. Miirk
    Miirk What's a Dremel?
    26 Jul 2004
    Definitely not a bad first mod! I kinda like the skull although it looks mighty displaced :D
  16. omicron
    omicron Baud.
    8 May 2004
    This is very nice for a first mod, but every time I look at the thread I hear "Gaping Lotus Experience" by Tool in my head >_< (specifically the 'Satan, sataan, saaatannn...' bit). Not sure about the skull though, its a cool ornament but looks kinda tacky on the computer imo.
  17. Bob 1234
    Bob 1234 What's a Dremel?
    5 Aug 2003
    Am I the only one to notice that the 5 pointed start is well pointed upside-down? As with the devil the single point is facing downward, if y'all don't beleieve me look at doom 3's icon and all the propaganda.
    -Bob
  18. omicron
    omicron Baud.
    8 May 2004
    Good point..thats a wiccan pentagram, no?
  19. PlagueH4
    20 Aug 2004
    This is not finished project yet, the skull is not atached so it can be moved whenever i want, i haven't decided to leave it or not yet. as for the name it's just a primary name, the finished project will have another if i can think of something :D
  20. PlagueH4
    20 Aug 2004
    I think it doesn't realy matter, look for pentagram all over inet, you can put it the way you want.
