http://stores.ebay.com/Chi-Wing-LED-product-shop i think thats what he meant by hong kong? yes/no? this definately looks to be interesting, im following!
The radiators (by themselves) are more effective than the TEC chiller (by itself) at removing heat from the coolant. Together, they are even more effective.
those LEDs are expensive... heres where i get cheap LEDs http://stores.ebay.com/BestHongKong-LED-and-More_W0QQsspagenameZl2QQtZkm
another good store. thanks. Anyone bought 10,000 MCD blue LEDs before? They are available at both of the stores mentioned, I want the brightest ones possible. It would be cool if I could get a comp. between these and some other light source (for example, I think the LED on the center channel speaker of the logitech z640s is really bright, but not as bright as 10,000 MCD)
My 4000 MCD LEDs are much brighter than the power LED of my Z-640s. 10000 would just blow my away. For comparison, I think the LEDs in mice are 4-5000 MCD.
wow, much brighter than the z 640s? thats crazy haha! I think im getting a 50 pack of 7000 MCD for 10 bucks free shipping thanks /end hijack
Hey vonk, your not still working on this insane project are ya? Wish i could get one of those 'bender' chillers here in uk then i could show you how its spose to be done slater..
hey vonk long time no see quick question and it doesnt have to do with your modding so much as a research thing im doing . in this pic you have 2 cores. would you say thier total thickness is about 6cm in the config you have? ?
I'm not using those Caprice cores anymore... although it *did* break my heart to trash a few chromed cores due to a slippery hand. I could get their measurements if you wanted. The new cores are about 2 kilometers high.
