Modding Pure UV light?
Discussion in 'Modding' started by ConKbot of Doom, 17 Nov 2003.
  1. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    There is all these UV reactive items, but what I want to know is there a CCFL or LED that puts out UV and no visible wavelengths?
    Or a filter, so that way there is no purple glow, just the reacive things lighting up.
    thanks
  2. Fatboy
    Fatboy Bored
    8 Oct 2001
    I do think there are LED's , but im unsure about cold cathodes, as the only ones i have ever seen are the pupleish ones and also the ones witht teh black coating, which are better.
  3. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Some UV tubes for EEPROM erasing are pure UV.
    But Pure UV is very bad for you.
    CCFL's and most LED are "Near UV" light, kinda like Near IR leds
    They are close enough to create the effect, but not damage your eyes.
    (Just like near IR leds put out IR light, but not IR heat)
  4. diskreet
    diskreet What's a Dremel?
    1 Oct 2003
    Thanks for the lesson Zap, never knew that!
  5. Bossman
    Bossman What's a Dremel?
    6 Nov 2003
    Yeah me neither, cheers!
  6. ConKbot of Doom
    2 Jul 2003
    same here. That could have ended up something ugly
    who needs a bios anyway.
  7. megaglowz
    megaglowz What's a Dremel?
    10 Oct 2003
    they use pure uv in salt water aquariums to kill bacteria.
    i use a uv light when i do windshield repairs...it says on the light not to look at it....
  8. ZapWizard
    19 Sep 2002
    Oh ya, there are pure UV lights in those UV bacteria killing things you see at resturants.
    But even those still put out blue light.
    (They look like a weird upward pointing light fixture attached to the wall for no reason)
  9. megaglowz
    10 Oct 2003
    always wondered what those were...lol
  10. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    isn't ultra violet in the visible spectrum? I know its on the fringes but Isn't it still on the edge of the visible spectrum?
  11. Zeke_D
    Zeke_D What's a Dremel?
    1 Oct 2003
    Ultraviolet light is that portion of the electromagnetic spectrum that lies beyond the “purple” edge of the visible spectrum and has wavelengths between 100 and 400 nm. The UV spectrum is further divided into ranges as follows:
    Range Name Wavelength Range (nm)
    UVA 315-400
    UVB 280-315
    UVC 200-280
    Vacuum UV (VUV) 100-200
  12. TwiSteD LoGic
    TwiSteD LoGic What's a Dremel?
    1 Nov 2001
    Just FYI visible spectrum is from 400 (purple) to 750 (red)...
    Cheers
