Modding Question aobut Cold Cathodes
Discussion in 'Modding' started by Cicada, 7 Jan 2002.
  1. Cicada
    Cicada What's a Dremel?
    29 Nov 2001
    how many can you wire in a single computer? i know that some have the "pass through" type of power connectors and was wondering if oyu cna jsut keep connecting them together forever....
    whats the most you can put?
    i ahve 3 in mine, and was windering if i cna put even more....
  2. Guest-16
    Guest-16 Guest
    Depends on your PSU rating. They take about 3 watts each im told, so not that much.
  3. Cicada
    29 Nov 2001
    i have a 400 watt psu.....
    i wonder how much my other devices take up...
  4. sTevE
    sTevE What's a Dremel?
    12 Dec 2001
    I have 3 in mine all tied together and i have a cheapo 250w psu.
  5. ChriX
    ChriX ^
    30 Aug 2001
    you dont have to have them all in line using those pass through connectors, you could just wire them all into one power connector or onto a switch, then it would keep the wiring neater too.
    Yeah, theoretically you should just be able to keep adding them until the psu can no longer cope, but I would say thats going to be a damn lot of cathodes :)
  6. Warbear_nG
    Warbear_nG What's a Dremel?
    27 Dec 2001
    but as cathodes are so bright - why use so many?
    sounds nuts to me
  7. Phil
    Phil What's a Dremel?
    19 Jul 2001
    you'll run out of places to put them before you run out of power.
    think about it.
