Modding Question for Lian Li v2000 owners..
Discussion in 'Modding' started by NightCrawler™, 11 May 2006.
  1. NightCrawler™
    NightCrawler™ What's a Dremel?
    11 May 2006
    The wires from the front bottom panel.. especially the USB one... at the end there are two connectors. One is a regular USB connector and on that wire it has separate smaller connectors zip tied back on the wire which seem to indicate a normal USB connection but with separate plugs..
    The question is do I need to plug them on the mobo (I have room for it) or can I simply cut them away as it looks awful with those pins tied back and i want to sleeve the wire regardless..
    Any help/advice.?
  2. Oxnard
    Oxnard What's a Dremel?
    6 May 2006
    OK those are for a motherboard that doesn't fit the standard USB block, as far as I know, thats old and obsolete, I simply taped mine though...
  3. GiGo
    GiGo was once a nerd.....
    12 May 2002
    Yeah, what Oxnard said, altho I have to use mine as the headers are in a crappy place on my board.
    Regards
    GiGo
  4. NightCrawler™
    11 May 2006
    I had a quick look on the Lian Li site and it got more confusing to be honest.. I need the extra set of pins for USB2.0 :confused: http://www.lian-li.com/faq.htm (scroll down)
    So for now I've connected the extra set to my DFI and see how it goes.. It does look more aesthetic then it was though..
  5. Oxnard
    6 May 2006
    No man, the block does 2.0 as well, all I use is the block...
  6. NightCrawler™
    11 May 2006
    You were right... I hooked up my USB wheel today and it refused to work because I had the other connectors hooked up too..
    After I pulled them it worked just fine.. :)
    Thanks for the help!
