Modding quick cooling Q..
Discussion in 'Modding' started by Smilodon, 26 Jul 2004.
  1. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    i'm going to replace the fans in my case (4 80mm fans) with 2 120mm papst fans... I'm a little unsure of the placement though...
    one of them will go in front of the harddrives (front-bottom), but i'm wondering if i should put the exhaust fan on the top (blowhole) of the case or in the rear...
    Any idea what will be most effective?
    (btw: i have a PSU wich have a 120mm fan in the bottom (right above the CPU)
  2. stoned penguin
    stoned penguin What's a Dremel?
    23 Mar 2004
    i have found that my blowhole removes a great deal more amount of hot air than my 2 exhaust fans in the rear do, but the 120mm in your psu should keep that area near your cpu and graphics card cool enough
  3. Smilodon
    25 Mar 2003
    Looks like i should make e blowhole then :)
    Now i just need to find some 8mm plexi...
