Quick RAID question
Discussion in 'Tech Support' started by Muffins17, 14 Dec 2007.
  1. Muffins17
    Muffins17 What's a Dremel?
    12 Dec 2007
    Just want to double check, its my first time with raid, when i ormat the hard drives do i format first then put the raid drivers on, or put the raid drivers on then partition them and that.
    A bit mroe of an in depth answer than i'm asking for, on the whole raid setup process, would also be much more appreciated.
    Thanks! :D
  2. Glider
    Glider /dev/null
    2 Aug 2005
    On a HW RAID, you first create the array, partition it if required, and then format...
  3. Muffins17
    12 Dec 2007
    Thanks.
    When do the drivers come in? After partitioning, before formating? Or after format, before OS install?
  4. JoeJones
    JoeJones What's a Dremel?
    24 Nov 2007
    Drivers will come into play during OS install...you may need them or may not..depends on OS and HW RAID controller used.
  5. jkeyser14
    jkeyser14 What's a Dremel?
    26 Mar 2006
    Check your motherboard instructions. I had to create my partition using my raid controller before going into windows install, then as soon as you get to the windows install screen, hit f6 and wait, it will eventually prompt you to put a disk in to install the drivers. After that, you format the drives when installing windows on the partition.
  6. Muffins17
    12 Dec 2007
    Sweet, cheers for the help guys. I feel enlightened.
    Anyone got a rough figure for waht i can expect for an increase in load speed (decrease in load times), compared to a singel drive of the same kind?
    Thanks
  7. Glider
    Glider /dev/null
    2 Aug 2005
    None... Load speeds are determined by seek times, which don't increase a single thing... You have just been fooled by the RAID 0 myth...
    EDIT: if you want faster loads, defrag your disk ;)
  8. Major
    Major Guest
    Blimey, I was just about to ask the same question on the forums.
    Think I'll get a freind to do it all though as I have no clue about RAID0 setting up. :)
  9. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    At this point, the only thing a stripe array is good for is if you have a bunch of smaller drives and want to have one large drive or partition. There are no discernible speed differences. If you want that, defrag often and/or buy a Raptor. ;)
  10. Glider
    Glider /dev/null
    2 Aug 2005
    If you have no idea what a RAID 0 array is/does, better stay away from it...
  11. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    and if you do, your better off staying away from it
  12. Glider
    Glider /dev/null
    2 Aug 2005
    If you do, you would never use it ;)
  13. Muffins17
    12 Dec 2007
    Alright, might keep it as two seperate 500's, but i do want 3 partitions, so it would make that awkward with sizes, but easier, we'll see eh. Might buy some raptors
