Case Mod - In Progress Raidmax Black Edition 4
Discussion in 'Project Logs' started by azazel.pt, 16 Jan 2011.
  1. azazel.pt
    azazel.pt What's a Dremel?
    16 Jan 2011
    Hi bit-tech user´s I will present my project which is currently in progress I'm making a new modding to this box that was already installed in three different ways this will be the 4th version of this box.
    Hardware to be used.
    < Hardware >
    Processor: Intel Core2 Quad Q6700 2.66 OC 3.4
    Motherboard: Asus P5Q Deluxe
    Memories: OCZ DDR2 PC2-9200 FLEXXLC EDITION
    Graphic Card: Nvidia XFX 285GTX 1G
    Hard Drive: Raptor 37G 10000 RPM
    Power supply: CORSAIR 620W Modular
    Case: Raidmax Scorpio 868
    < Watercooling >
    Processor: EK Supreme
    Pump + Reservoir: ALPHACOOL AGB-EHEIM 600 STATION II 12V MOLEX
    Radiator: BLACK ICE STEALTH GTX-LITE-PRETO 360
    Connectors: INNOVATEK G1/4
    Tube: INNOVATEK TUBO 8/10 Parede rigida
    Liquid: FESER ONE UV BLACK
    Fans: 3 X REVOLTEC LEDS RED 120MM + 2 X REVOLTEC LEDS RED 80MM
  2. azazel.pt
    16 Jan 2011
    The first images of the feet of the case.
    without being filed and sanded.
    After filed and sanded.
    I used two sides of an old case to make the false interior panels.
    Only for those who can my uber leet tractor to plow, in my hands fly up to 5 km hour hahahahhahahah :rock:
    Some work done.
    Next phase will be stripping all the paint of the case make small prominors missing for routing cables and paint, the cables will not carry sleeve will all be replaced with black cable and for whom no noticed this source case is ATX has been changed to BTX.
    I leave here some pictures of pre assembly just to see if everything is all right, there are 2 acrylic pieces that are already made but I do not have photos i will take them later.
  3. tkgclimb
    tkgclimb man it's all harder than it looks
    18 Jan 2010
    great craftsmanship, those feet look sweet
  4. azazel.pt
    16 Jan 2011
    2 pictures just for you :naughty:
  5. azazel.pt
    16 Jan 2011
    + 2 photos of acrylics that were missing one of the front to replace the original and another for the top :duh:
  6. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    This is spooky. We use the same alias, more or less, and you're doing a mod somewhat similar to my first one (Purple Dragon). Looks good so far! :p
  7. azazel.pt
    16 Jan 2011
    Mini update
    I leave a mini update, since the box had three different layers of paint could not finish everything today.
    Phase 1 rivets out.
    Phase 2 spread paint stripper.
    Phase 3 scrape.
