Scratch Build – In Progress Rate my Scratch Build Plans!
Discussion in 'Project Logs' started by JoeMunky, 21 Apr 2009.
  1. JoeMunky
    JoeMunky Professional Playdough Taster
    16 Mar 2009
    Hi all, hope I've posted in the right place :thumb:
    Here are my plans for my new build over the next few months.
    CPU: i7 920 2.66GHz
    RAM: Corsair Dominator 6GB (3x2GB) DDR3 PC3-12800C8 (1600MHz) Tri-Channel
    GPU: BFG GeForce GTX 285 OCX 1024MB
    Case: Silverstone Temjin TJ07B-W Aluminium Tower Case with Window
    Mobo: Asus P6T Deluxe Intel X58
    PSU: Be Quiet! Dark Power Pro 1000W
    HDD: 1x Samsung SpinPoint F1 750GB SATA-II 32MB Cache
    Right, thats the skeleton of the shopping list. I'm thinking so far of watercooling with two loops, and in that case;
    CPU: Swiftech Apogee GTZ (Incl. Backplate for LGA1366)
    GPU: EK GTX 285 SLI Plexi Full Cover
    Rad: Thermochill PA120.3 120mm Triple Rad & Thermochill PA120.2 120mm Double Rad
    Pump: Swiftech Laing D5 Vario MCP655 x2
    Res: EK Multioption Reservoir 250 x2
    I'm planning on mounting the 2x120mm Rad at the op of the case for the GPU, and having the Triple rad at the bottom for the i7
    I haven't planned any serious mod's yet, becuase the build isn't starting for at least a month so I'm just reading around for inspiration :) Plent of UV to come though :dremel:
    Total build cost Est: £2000 :wallbash:
    Any thoughts anybody?
  2. Spyrious
    Spyrious Modding all the Time
    8 Dec 2008
    I think you posted in the wrong section.
  3. Geowal19
    Geowal19 What's a Dremel?
    16 Apr 2009
    Scratch builds in this section don't mean just building a comp it means auctually making a case from bits of metal or sheet materials.
  4. Geowal19
    16 Apr 2009
    You only get one. Tell him peter. "Aparrently you only get one"
