Cooling Reccomend me a block that takes 3/8" tubing
Discussion in 'Hardware' started by couzo, 1 Oct 2004.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    I have had a 1/2" tubing setup for a while now but want to go to the smaller tubing size and want to know if you guys can reccomend me some places in teh UK that sell these sort of blocks and some that are great performers and yes I know about wizard design but just want to know any other that perform well.
    Thanks
  2. Risky
    Risky Modder
    10 Sep 2001
    You're taking 10mm OD tube and pushfits so you have a fair choice of manufacturers. Off the top of my head
    www.Asetek.com
    www.watercool.de
    www.alphacool.de
    Asetek waterchill is widely available.
    Watercool.de is stocked by Kiomplett as is Alphacool which is alsa at wizd and several others.
    you can mix and match between these.
    More later as I'm rushing.
  3. Nexxo
    23 Oct 2001
    Are you talking about 3/8" ID or OD?
  4. couzo
    26 Apr 2002
    I am talking about 3/8" id tubing like waterchill and swiftech use, I have seen good reviews of the 6000 block by swiftech and it not a bad price
  5. Risky
    Risky Modder
    10 Sep 2001
    Then scrub my original recommendations, this is 1/2" OD and yep its just waterchill and swiftech to choose from unless you want to buy your own fittings.
  6. couzo
    26 Apr 2002
    the alpha stuff looks great and I really like the aqua tube res with the dome very cool I may go for their stuff if shipping is ok
  7. Risky
    Risky Modder
    10 Sep 2001
    alas you'd neeed to find 1/2" OD 1/4 BSPP fittings if you want that tube.
  8. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    dont forget dangerden!
  9. couzo
    26 Apr 2002
  10. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    if it was me, i would go for
    a NexXxoS XP Bold or a NexXxoS HP Pro for the cpu. an Alphacool Chipset block for the nb and a Aqua Computer vga block. all tied together with some blue uv tubes. and for the res
    http://www.wetandchillychips.co.uk/catalog/index.php?cPath=29
    as you already have a great radiator, with one or two of these you may get away with passive cooling! especially with winter around the corner!
  11. Nexxo
    23 Oct 2001
    DangerDen does all its blocks in both 3/8" ID and 1/2" ID versions. All you have to do is specify what barbs you want fitted when you place the order. :thumb:
  12. kbn
    kbn What's a Dremel?
    17 Mar 2004
    Keep your existing 1/2" bliocks and just change the fittings? they all use 1/4" BSPT anyway...
  13. buchans
    buchans What's a Dremel?
    28 Jun 2004
    you can actually use 3/4 ID tubing with 1/2 ID fittings, I've used it and it works VERY well, its an effort to get the tubing on but it won't come off - I don't even use clamps
  14. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Erm dude, you do mean 3/8 right? and along with that, you need to boil some water and put the tube's end into it to make it loosten up.
  15. Risky
    Risky Modder
    10 Sep 2001
    Just for carification are we aking about using 1/2" OD tubing with pushfits (as per waterchill, swiftech) or using 3/8" ID tube with 3/8" barbs?
  16. Firehed
    15 Feb 2004
    God I hope so lol.... I'm just imagining that one. "Without clamps" - must be about a gallon of plumbers goop :hehe:
    Dunno about the availability of Polarflo blocks over the big pond, but they're next on my list. Or just change the fittings and save a rediculous amount of money.
  17. silentphoenix
    silentphoenix What's a Dremel?
    1 Sep 2004
    The asetek antartica is meant to be decent, and the new Zalman water block edges it by about a degree. I think both are available for about £30 at tekheads.
    Im thinking of using 3/4 hose. How did you get it on 1/2 inch fittings - did you just shove in a piece of 1/2 inch into the 3/4?
  18. Darv
    Darv Bling!!
    12 Aug 2002
    Just use 3/4 barbs. Simple.
  19. Risky
    Risky Modder
    10 Sep 2001
    I think there some confusion here. Is anyone here using
    3/4 ID" tubing or is there a typo?
  20. couzo
    26 Apr 2002
    Wow 3/4"id the OD would be huge!!! I am going to go for a nexxxo set up looking at reviews it performs very well and look cool thanks for all the input guys :)
