Modding Remove / Disable Zalman fan LEDs
Discussion in 'Modding' started by kingdavies, 27 Jan 2007.
  1. kingdavies
    kingdavies Minimodder
    29 Aug 2004
    How can I remove (or disable) the annoying green LED's from my Zalman CNPS9500 AM2, I plan on buying a Zalman Fatal1ty FC-ZV9 I think its so stupid how they can't put matching coloured LEDS in them both.
    Thanks
    Kingdavies
  2. Guest-23315
    Guest-23315 Guest
    I guess you can find where they connect onto the fan's power cable and cut / de-solder them off.
    Otherwise you're pretty much stuffed ;(
  3. kingdavies
    29 Aug 2004
    I was thinking that but how do you get at the LEDS, is it possible to remove the fan blades from the heatsink without breaking it
  4. Guest-23315
    Guest-23315 Guest
    I'd say dremel them out from the back, but then you're fan would very probubly fly apart probubly hurting you / your PC / your possesions
  5. brimal_rage
    brimal_rage What's a Dremel?
    28 Jan 2007
    use a phillips screw driver and unscrew the mount. the fan is on a mount that screws to the bottom plate, you can unscrew that and remove the fan i believe. then you find the leds and desolder them apart, but im unsure as to removing the fan to get to the leds. either way good luck, i know i want to change my leds myself.
  6. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    Just a thought but you could remove the LED's on both and then add the proper color to both so that they do match. LED fans in which the LED's have been removed look a little dorky.
