SATA Probs
Discussion in 'Tech Support' started by subterrian, 28 Sep 2008.
  1. subterrian
    subterrian This is the end
    28 Aug 2008
    I have computer that was recently rebuilt, and all my data is on an old IDE drive, i bought two SATA drives: an 80gb, and a 140gb. I plan on mirroring the data from the IDE to one of the newer drives. But windows doesn't recognise the two new drives. but the BIOs on the other hand does.
    the Motherboard is:
    K8VGM-V
    VIA k8M890 + VT8237A Chipset Based
    the processor is:AMD Athlon 64 X2
    Dual-Core
    and i'm running: XP Professional SP2
  2. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Don't make two threads on the forum. There is simply no need for it and it is really annoying.
    Have you tried to see if the system can pick up the discs in Disc Management? Try formatting the discs in there (type 'compmgmt.msc' in the 'Run' box, then click 'Disc Management').
  3. subterrian
    28 Aug 2008
    think i haven't tried that? thats the most obv answer to the problem, and the first thing i did
    "edit"
    they dont appear there either
  4. lamboman
    25 Jul 2006
    No need to be harsh about it. Some people do it, some people don't. The amount of knowledge people carry on this forum varies greatly, and I have no way of telling whether you have strong or weak knowledge in computers.
    Try reinstalling your motherboard's SATA controller drivers.
  5. subterrian
    28 Aug 2008
    again alreadt tried, multiple times
  6. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Okay now. We don't know what you've already done if you don't state it anywhere, ffs. :rolleyes:
  7. subterrian
    28 Aug 2008
    Dont post if you dont have anything to say. /\/\
    Things I've Tried:
    Disk Mangenment
    Booting a Linux Live CD
    Reconfiguring the BIOs
    Happy now?
  8. mm vr
    18 Nov 2007
    I indeed had something to say...
    Why could you not just post these things right away, in your first post? There would have been a lot less hassle.
  9. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    boot from windows install disk, see if drives show up there and if so format
    drives showing in device manager?
