A/V Sharp 5" LCD
Discussion in 'Hardware' started by Vio1, 14 Apr 2005.
  1. Vio1
    Vio1 What's a Dremel?
    29 Mar 2004
    Hi guys, i have a 5" LCD made by Sharp, and I wanted to get some stats, but i have no idea where to find them... here is the lcd:
    Any ideas?
  2. Vio1
    29 Mar 2004
    anyone?
  3. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    It looks like it has a composite video connector, correct? What you need is a graphics card with a composite video output. IIRC, it's possible to do it with an ATI AiW card, but you can buy PCI cards that will do it to.
  4. Hwulex
    Hwulex Minimodder
    1 Feb 2002
    What do you mean, stats?
    Do you mean PC stats to display on the screen, or do you mean technical specifications about the screen itself?
    If the former, then as TekMonkey said, although any SVideo or Composite out card will do. SVHS to Composite converters are just a small dongle and are very cheap. :)
  5. Vio1
    29 Mar 2004
    Hi, sorry for the mix up... i know how to get it working, but i want to find out the monitors' actual stats... like what is native resolution is, etc... its specifications: product details.... im trying to sell it, and i need to know more info on the actual product.
  6. TekMonkey
    6 Dec 2002
    Okay, it looks like the model number says DUNTK2655TPZZ, but Google has nothing for that. Look for any other model number or any type of id on it and Google will be your bet.
  7. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    could be this one LM32019T. cant say it for shure. a pic of the controller card would be good. where you got it from?
  8. Vio1
    29 Mar 2004
    I got it from another guy on the forum... Which part is the controller?
  9. antiHero
    19 Jan 2005
    should be the part you fliped away from the lcd on the last pic. just take a couple of close ups from all parts. front and back! then i can have a look on it
  10. nick[x1]
    nick[x1] What's a Dremel?
    1 Nov 2004
    The bit fliped away looks like the settings board with buttons on?
    If you could take the lcd controller (circuit board on the back of the lcd) off there should be a model number on the back of the backlight module which should be a starting point :)
    Just be carful with that brown fcc cable dont want it snapping :)
  11. davidsonesq
    davidsonesq What's a Dremel?
    23 Apr 2005
    screen model
    Hey, if you havent already found out it is a screen from made by ''Directed Video'' its model number is ''HVM500'' I stumbled across this site while looking for wireing diagrams for it as mine dont have the DIN cable
