Modding Shuttle IDE mod
Discussion in 'Modding' started by cyrilthefish, 23 May 2004.
  1. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    Bit of an odd problem here, but to make my life easier, i'd like to connect one of the internal IDE ports externally.
    current setup:
    primary IDE - master - 80GB drive
    primary IDE - slave - empty
    secondary IDE - master - 160GB drive
    secondary IDE - slave - empty
    firewire/USB 2.0 port - DVD-RW+- external drive ( non-bootable :( )
    as my CD drive enclosure is non-bootable it makes installing an OS a real pain (ie 6x boot floppies to install XP for instance)
    Now in my shuttle XPC, i have absolutely no use for the parralell port, so the parralell port cutout on the back is free.
    parralell = 24 pins (if i counted right)
    IDE = 44 pins (40+ 4 power)
    how many of these pins are strictly nessesary?
    it'd only be for connecting an old CD drive that is bootable, signal quality being degraded by reduced amount of ground lines would be no problem.
    Or alternatively, are there any connectors of around 40 connectors that are a simalar size? i'm having trouble finding anything myself.
    not a huge problem, but it'd be much neater than having a IDE cable and molex connector poking out the back of the PC like it is at the moment
  2. MechWarrior
    MechWarrior What's a Dremel?
    13 Oct 2003
    Why not keep the HDDs on the same IDE channel?
  3. Morphine
    Morphine weeee!
    23 Feb 2002
    every other pin on an IDE cable is a ground wire.
  4. Xipher
    Xipher What's a Dremel?
    25 Apr 2004
    For proformance reasons.
    Deepends on cable, the 80 wire ones thats true, but the 40 wire ones are different
  5. BjD
    BjD What's a Dremel?
    10 Apr 2003
    IDE pinout
    Dont think you can trim that down to 25 pins :D Does the motherboard support booting from USB or is it the enclosure that wont do it?
  6. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    If u did away with a floppy drive im sure u could cram 2 hard disks and a cd-rom inside their no problem. A friend of mine has done fine and then uses a usb floppy drive if needs be.
  7. unleashed
    unleashed What's a Dremel?
    7 Mar 2002
    nope doesn't look lit you'll be able to cut it down to 25 pins :( - see IDE pinout below:
    Pin Description Source Acronym
    1 Reset Host RESET-
    2 n/a Ground
    3 Data bus bit 7 Host/Device DD7
    4 Data bus bit 8 Host/Device DD8
    5 Data bus bit 6 Host/Device DD6
    6 Data bus bit 9 Host/Device DD9
    7 Data bus bit 5 Host/Device DD5
    8 Data bus bit 10 Host/Device DD10
    9 Data bus bit 4 Host/Device DD4
    10 Data bus bit 11 Host/Device DD11
    11 Data bus bit 3 Host/Device DD3
    12 Data bus bit 12 Host/Device DD12
    13 Data bus bit 2 Host/Device DD2
    14 Data bus bit 13 Host/Device DD13
    15 Data bus bit 1 Host/Device DD1
    16 Data bus bit 14 Host/Device DD14
    17 Data bus bit 0 Host/Device DD0
    18 Data bus bit 15 Host/Device DD15
    19 Ground n/a Ground
    20 (keypin) n/a Reserved
    21 DMA Request Device DMARQ
    22 Ground n/a Ground
    23 I/O Write Host DIOW-
    24 Ground n/a Ground
    25 I/O Read Host DIOR-
    26 Ground n/a Ground
    27 I/O Ready Device IORDY
    28 Spindle Sync or Cable Select (note 1) SPSYNC:CSEL
    29 DMA Acknowledge Host DMACK-
    30 Ground n/a Ground
    31 Interrupt Request Device INTRQ
    32 16 Bit I/O Device IOCS16-
    33 Device Address Bit 1 Host DA1
    34 PASSED DIAGNOSTICS (note 1) PDIAG-
    35 Device Address Bit 0 Host DAO
    36 Device Address Bit 2 Host DA2
    37 Chip Select 0 Host CS0-
    38 Chip Select 1 Host CS1-
    39 Device Active or Slave (Device 1) Present (note 1) DASP-
    40 Ground n/a Ground
  8. Blue Raven
    Blue Raven What's a Dremel?
    25 Sep 2003
    Go to an electronics store and buy a long ribbon cable and 3 40-pin female connectors. They are quite easy to put on the cable; they come in 2 parts that pinch the cable between them onto sharpened connectors. Mount one for the motherboard, then measure how long it needs to go to get to the first hard drive. Clip the second connector on there. Get the polarity right, there is a red or striped wire on one side of the cable to show polarity. Figure out how long the cable needs to be to the third connector and put it on there. The distance between the second and third connector should be long enough to go outside the case. Between the second and third connector, cut in-between every 5th or 10th wire and pull the wires apart so you will have a bundle of lots of thinner ribbon cables. Use cable ties and braiding to clean it up and then rout the 3rd connecter out through a hole in the case. When the wire is not in use, you can bundle it up inside or behind the case. When you need to use it, plug the cd rom into the ide cable and use a Molex extension to get power to the cd drive.
    Another thing that you could try is buying 2 male 40-pin ide connectors and soldering them directly together. Cut a hole in the back of the case and glue the 2 plugs into the hole. So you have an ide plug on the inside and on the outside. Do the same with a male Molex plug. plug the 3rd connector on you current ide cable onto the inside half and when you need to use the cd drive, just get a Molex extension and short ide cable to plug in a cd drive.
  9. Twunka
    Twunka What's a Dremel?
    12 Feb 2004
    umm why not just use cable sleeving and sleve the ide (round it first) and the molex together.
