Windows Simple free splice and video editing software
Discussion in 'Software' started by Kronos, 1 Nov 2015.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    Took a video or rather several short clips of my cat accompanying me to the paper shop this morning. But cats being cats and not sticking to the pavement and going under cars I need to edit the clips then hopefully splice them into one reasonable clip. So looking for a free simple program.
    Simplicity is the key word here and I mean simple for a noobie such as me.
  2. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    Windows movie maker is pretty simple, it's part of the live applications
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    The first thing that springs to mind is Windows Movie Maker. I think it should do all that you want.
    Edit: Ninjad. Bah :p
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    Cheers guys will try that though I suspect it is unnecessary given the quality of the video clips. I really do not think DLSR and video should be in the same camera. Will need to get my hands on a cheapish stand alone video camera.
  5. Vault-Tec
    30 Aug 2015
    Virtualdub.
  6. techmonster
    techmonster What's a Dremel?
    24 Sep 2015
    I recommend Pinnacle or Windows movie maker for Windows processor. They are simple and easy.
    And recently i used Video Pad v4, since i wanted a light program. The good thing about Video Pad 4 is the automation of sound waves and adding that audio effects with modulations.
  7. Goatee
    Goatee Multimodder
    19 Apr 2015
    I like Windows movie maker, really simple and easy to use.
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
    At the moment I do not have a suitable quality of video to edit but might try something with the rubbish I have. If I get it wrong, (likely) then no harm done.
    Thanks for the suggestions.
