Windows Smartie + VFD
Discussion in 'Software' started by Hwulex, 17 Jan 2003.
  1. Hwulex
    Hwulex Minimodder
    1 Feb 2002
    = fubar.
    I had this VFD working ages ago, but can't remember what software I used. Anyway, I thought I'd use Smartie, as I've used it before, but when I load it, this happens:
    Tried copying the supplied DLPORTIO.DLL but no joy. Also Googling to no avail.
    Sorry for being a n00b. :blush:
    Hwu
  2. linear
    linear Minimodder
    5 Oct 2001
    Is that the latest smartie? I had some similar problems with a .0 release of it, but it got fixed and I heard the the latest one was b0rked again too.
  3. Kipster
    Kipster What's a Dremel?
    19 Aug 2001
    I got the same prob here, but now use Jalcd, its way better.
  4. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    It does that on mine when I run Motherboard Monitor.
    Just check you've not got something running like that. That may help you out.
  5. Hwulex
    Hwulex Minimodder
    1 Feb 2002
    jaLCD looks *very* good.
    Unfortunately, it has the same problem, only less severe than Smartie's. :(
    I have nothing of similar nature running in the background.
  6. ndtinker
    ndtinker Car Washoholic
    23 Sep 2002
    Sounds like something else causing you problems. I keep both jaLCDs & Smartie up to date and have never had peoblems with either.
    Maybe I'm just special :D
  7. Cheese
    Cheese Doc
    6 Oct 2001
    Had this problem a few times, reinstalling a few times always seems to sort it...
    Smartie is a bit rubbish though, you wouldn't catch me using it :)
    Rob.
  8. Hwulex
    Hwulex Minimodder
    1 Feb 2002
    Any more thoughts?
    Still having the same problems :(
  9. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    You MUST install the I/O port driver if you are using 95/NT/2000 or XP. (Here is the link).
    Hope it helps....
    GeeK!
  10. papeniglio
    5 Dec 2002
    Forgot to say I used it with LCD Smartie and worked.
    GeeK!
  11. Hwulex
    Hwulex Minimodder
    1 Feb 2002
    Excellent mate, thank you very much! :D
    So, no more errors. But both Smartie and jaLCD just make it either blink a box in the middle, or just spew random garbage :blah:
    I'll look at the configuration, or I suppose a wire could've come loose somewhere with it being chucked around in my 'spares box' :blush:
    <EdiT>
    Looks something like this:
