Small Form Factor SN45GV3 RAM Issues
Discussion in 'Hardware' started by Aa-chan, 23 Jul 2005.
  1. Aa-chan
    Aa-chan AA-CHAN
    8 Jul 2004
    It's been a while since I last built a Shuttle and wanted to confirm something.
    Firstly, having two Corsair sticks in at once causes it to blue screen a lot and generally make a nuisance of itself. Is this the Shuttle being picky about what it eats, or is there a simpler solution to this? I couldn't see anything in the BIOS particularly related to my problem, so that's why I thought I'd ask here.
    Any suggestions?
  2. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    With my experiences the SN45G hates all ram, I have tried so many stick with the one i used to have and it was always unstable. Thats why shuttle pulled the SN45G off the market.
  3. pritsey
    pritsey Minimodder
    26 Nov 2002
    I have a SN45G, I had problems with mixed makes of RAM, but now I have PC3200 cheapie stuff from Aria and it works a charm!
  4. Hiren
    Hiren mind control Moderator
    15 May 2002
    When I built my shuttle I also had issues with Corsair ram. In the end I just went for a matched pair of OCZ. That solved the problem.
  5. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    Crucial works fine and as overclocking is very limited I see no reason for going for fancy ram.
  6. TMM
    TMM Modder
    12 Jan 2004
    What kind of voltage are you feeding the Corsair? usually corsair specs their ram for 2.8v stock. ... or is it one of those shuttles that selfdestructs when you try and change the vdimm? :lol:
  7. Aa-chan
    Aa-chan AA-CHAN
    8 Jul 2004
    It was just running at Auto. I shall poke it some more and suggest to my friend that he might stick it up to 2.8V.
  8. tm36usa
    21 Jan 2004
    Yep, and shuttle doesnt even tell you about the issue. I think in the newest bios they disabled changeing it but im not sure. Thank god new egg took that pos back.
  9. Aa-chan
    Aa-chan AA-CHAN
    8 Jul 2004
    Does anyone know if Patriot RAM has issues with Shuttles?
  10. scotty6435
    scotty6435 What's a Dremel?
    4 Sep 2004
    The V3 shuttle had it's Vdimm option disabled to prevent frying the motherboard so he should be okay. AFAIK, 2.8V is the standard setting for 45G.
