Graphics [solved] No video signal
Discussion in 'Tech Support' started by JCG, 15 Dec 2011.
  1. JCG
    JCG What's a Dremel?
    1 Dec 2005
    I just build a computer, but I don't get any video signal out of the vga or dvi port.
    The specs:
    Intel Pentium g620
    Asrock h61m-gs
    Bios version: no idea, it's kinda hard to check that if you can't use a screen :p
    Ram: kingston KVR1333D3N9 4GB, it's one module so no dual channel stuff but that should matter for the video signal right?
    update: checked all the cables, all are were they are suppose to be.
    The voltages are within specs (used an old psu)
    The fans spin work
    the power led lights up.
    I heard the HDD spin up
    No buzzer in the computer (yet) so can't say if the motherboard is beeping at me. I'll try to find one today
  2. buchanan0204
    buchanan0204 What's a Dremel?
    15 Dec 2011
    Does the system POST at all? Any beeps, lights, fans or noises of any kind?
    Checked both the 4/8-pin EPS/12V and also the 24-pin?
    If yes. Try disconnecting everything not needed for POST. DVD drives, hard drives etc.
  3. JCG
    1 Dec 2005
    So to who do i need to send my computer-card when it's revoked?
    Apparently i did messed up putting the ram in. Because the computer started up perfectly after taking the ram out and putting it back in. The computer even loaded the old windows XP install that was on the hdd.
