Case Mod - In Progress SpeakeR Project [By Lawnmower]
Discussion in 'Project Logs' started by Lawnmower, 17 Feb 2008.
  1. Lawnmower
    Lawnmower What's a Dremel?
    2 Nov 2007
    [Hi everybody,
    for the everybody that doesn't know me, I’m Henry (in english) and i’m fourteen, the project which I wanted to risk, as the name says the name, is the realization of an acoustic box inside which I will put the hardware of my pc from scratch ……….
    …….. after almost one month of "ideation", I have begun to try to give form and measures to this "case" that will take then the name (thanks to the help of wolf) of SpeakeR Project.
    At this point I didn't have to do anything else other than to pass to the real thing…….. but before beginning, I have decided to consult some people really kind and cordial and above all with a lot of experience that is: Lupo, Rigor, e _FAX_..........
    Talk to you soon with the first updates!!!
    Therefore, for first thing I had to make sure about count me some approximate encumbrances of the hw and, appraise the possible positions………after some study (really few) here is thing has come out!!!
    afterwitch, takings some measures, have marked the compensated by to cut…..
    and I have made a further test before beginning to cut…
    considering that it was all well, I have performed the cut……(don’t have the photos of the workmanship in how much the photo camera had a bead battery…)
    It’s time to cut the panels and to see the real dimension of this box!!!
    Here it is with the hw supported inside……..
    and here are the walls of the houses to glue………
    (you excuse for the photo un focused….)
  2. Lawnmower
    2 Nov 2007
    Only that i have not found the screws that I looked for, therefore, I will use the nails to finish the fixing of the panels, thing that will do when the glue has ended to dry……. even now that it is not; totally dry it has a lot of resistance!!!!
    Boys, I have not found the screws that I was looking for, therefore the only solution were the nails……….. let's put them in!!!!
    particular nail….
    here is how the nail remains………
    once I put in all the nails, I have could not resist…….. I have taken its levels and I have given one measure to the bench…….. then the case……. as you see everything is perfect!!!!!, above all if we think that the angles must be smoothed… still…
    particular of the bead
    Here the beast used for eliminating the big one….. as you will notice it warts with compressed air…..
    particular of the disk…..
    photo of the workmanship
    written by Lawnmower; translated by Toby
    stay duned!
  3. bentleya
    bentleya Lian Li Snail :)
    2 Feb 2008
    nice work :thumb::thumb:
    the last work should be spelt tuned not duned :thumb:
  4. C:\Joshy
    C:\Joshy How much cake can you eat in a min?
    30 Aug 2007
    looking good so far:)
    i agree but i think you meen the last word....
    useless aint we .
    anyway good work :rock:
  5. bentleya
    2 Feb 2008
    yer i ment that:duh::duh:
