Modding starting of a case, design stage :)
Discussion in 'Modding' started by morishani, 27 Apr 2005.
  1. morishani
    morishani What's a Dremel?
    29 May 2004
    http://morishani.info/SFF.gif
    (Gif, 3 Frames, each 4 sec')
    Whatc'ha think?
    *The Case width is 40, not 35 :), height is about 20-19
    *The PSU is going to horizontal
    *The 2 Lower HDs is going to be below the PSU.
    *There is gonna be bays for the hd's , floppy, cd . (i just dont have enough power to draw them), their colour will be blue(plexi).
    *I think im going to sand the white plexi , so it will be more white :), i will c what is the white plexi opacity and then know.
  2. webbyman
    webbyman Hax.
    7 Oct 2004
    :jawdrop: Shexy idea... if it turns out anything like that... errm :jawdrop: :jawdrop: :naughty: :jawdrop: :D
  3. rob_65
    rob_65 What's a Dremel?
    5 Apr 2004
    Looking very nice!
  4. morishani
    29 May 2004
    I think tommorow ill buy some of the plexi. may-b :dremel: .
    eamm, and i should get a mail, if there is a sleeving kit in our little city,
    if not i should order it, and the order price is about 15$ :wallbash: .
    but the price of the sleeving is very cheap - 10$ :D
  5. jameswalker
    jameswalker What's a Dremel?
    1 May 2005
    What program did you use to make those images?
  6. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    looked like SketchUp to me...
  7. 69X
    69X What's a Dremel?
    14 Feb 2005
    how are u gonna deal with heating issues? powersupply/hard drive/cpu all close together will generate a LOT of heat
  8. morishani
    29 May 2004
    yes im :)
    i the cpu is a64 from the coldests, venice 939 90nm (3000+),
    or i'll stay with the current - P4 1.3 Cold 2, currently working on 35 degrees
    (thats becoz' my computer is 2 cold :\ , abmient - 25)
    but u know :)
    i thought about getting 80 mm in the back to get air inside, and change the cpu fan direction up.
    AND YES IT'S SKETCHUP.
