Windows stop msn from starting in registry...
Discussion in 'Software' started by keef247, 6 Jun 2007.
  1. keef247
    keef247 Modder
    11 Aug 2006
    msn registry key to block msn from opening.link?
    i need a code to put in a text file to make it a registry key to stop msn from starting.the same as you can get for windows messenger?
    help please!
  2. cannon
    cannon What's a Dremel?
    15 Jan 2004
    why dont you stop it under startup in msconfig?
  3. quack
    quack Minimodder
    6 Mar 2002
    There are 2 ways to do this,
    1) Using a .bat/.cmd file.
    Code:
    REG DELETE "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run" /v msnmsgr /f
    2) Use a .reg file.
    Code:
    Windows Registry Editor Version 5.00
    [HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run]
    "msnmsgr"=-
    You will have to remove the extra spaces inserted in the word "Current" by the forum software.
