Notebooks stupid lappy
Discussion in 'Hardware' started by FILTHY1337, 4 Feb 2008.
  1. FILTHY1337
    FILTHY1337 Senior Overclocker
    4 Jan 2004
    i have a dell e 1705, its had a rough life and the on board speakers no longer work, and i only get mono ( left channel) from the audio jack i currently have it apart and im typing on it still,...but i see no physical damage.i can take pics if it will help any suggestion is welcome.:wallbash::wallbash:
  2. mongoze
    mongoze I have a Dremel
    3 Jan 2008
    try to re-install the drivers. and try checking if there's any bad connections.
  3. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    As suggested... it 'sounds' like a loose/dodgy/broken connection/wire?
    If you can't trace/fix the problem... you could always just buy yourself a cheap pair of external speakers to plug in :idea:
  4. Mootown
    Mootown Camel Dung Dealer
    31 Mar 2007
    USB headset. Plantronic or Microsoft Livechat LX3000. MS one is good!
    Use small size cotton buds with a bit of WD40 and stick it in and clean it. Contact may have turned green inside.
  5. Hazardous
    21 Jan 2004
    Clean what / what contact?
    Assuming you mean the on-board sound chip... it's unlikely it will have turned green... unless something was spilled onto the laptop?
    And getting at the sound chip, will mean completely stripping the case down, to get at the mobo/chip... which the OP might not be too happy doing?
  6. FILTHY1337
    4 Jan 2004
    already have it stripped i see no damage but my lappy has attented parties and has been wet, i like the usb headset idea but is there a way to ue my aux jack as a output?
