Case Mod - In Progress super water cooling dual run system
Discussion in 'Project Logs' started by Robster, 21 Jul 2007.
  1. Robster
    Robster What's a Dremel?
    11 Dec 2003
    here is a comp just finished for a customer came out so nice had to post a few pics
    will do a run down on the build once i get a chance
    specs for comp are
    quad core qx6700 2.6 clocked to 3.625 running stable
    dual 8800 ultra superclocked
    dual 150 gig raptors raided and watercooled
    500 gig sata for storage
    killer nic card for gaming
    2 240 thermochill radiators one for the CPU the other for Vid and hardrives
    1 120 thermochill rad to help with vid and harddrives
    2 thermaltake pumps one for cpu one for vid and harddrives
    zalman fan controler
    Swiftech GTX CPU waterblock
    Swiftech Stealth waterblocks for vid cards
    and extras more to come
    3d Mark score 18501
    Your system compared to all 1880968 system configurations. There are 995 systems with a higher score and 1879973 systems with a lower score than your system
    will add more pics as well as some build pics later
    just want to see what you guys think
  2. Teyber
    Teyber ******
    18 Mar 2007
    amazing, except kinda troublesome that you wen't with thermaltake pumps... those leak and fail all the time and i advice you get some laing d5's or something like that.
    What gpu speeds are you running?
  3. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Wow nice specs but I think the Killer NIC is a scam
    Is that a Thermaltake Mozart??? What PSU are you using to power it???
  4. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    At the moment I don't feel the KillerNIC can be used to its full potential. Once games start using a lot of bandwidth, then that's when it'll start to come in handy to have a dedicated NPU.
  5. Sandwich
    Sandwich What's a Dremel?
    21 Jun 2007
    you forgot to mount a fan in the bottom left corner:D
    hehehehehe
    :jawdrop:at the cleanliness of it all. with all those wires and tubes you sure managed to make it quite clean. although I do wonder what this guy is gonna use it for...
  6. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Not dissing on you mate, looks really good. But what's the use off all those fans if you're having watercooling? In my humble opinion you could have gone with 2 fans on each rad, and possibly 2 fans in front and 1 in the back. Might have saved you half the noise I guess...
  7. [MadMan]
    [MadMan] What's a Dremel?
    3 Feb 2007
    i love that "resistance is futile" sticker lol :) nice add
    any pics of that WCed HDDs? internal shots PLEASEEE
  8. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Not everyone uses Watercooling for silence. In fact most use it for performance with overclocking.
  9. Robster
    11 Dec 2003
    I'm the client with this rig. Rob did a great job helping me with this build. As to some of the questions out there. its a mozart tx case( I had the armour lcs case before but not enough air flow and only a single loop system) power supply is a 1000w silverstone the Killer nic does make for smother game play as far a lag is concerned the ping control is nice if playing on servers that require me to increase mine for fair game play. so far very happy with how its turned out.
  10. Frido
    Frido Minimodder
    19 Apr 2007
    Must be a hell of a f***ker to lift around the different LANs :)
    Awesome hardware, sounds prette expensive, huh? Nevertheless, nice setup!
    I'm sticking with the statement that there's too many fans and I recommend laing pumps too (got one myself, works like a charm, great flow minimal noise) - but if it's solely for overclocking, I'd go for phase change, ought to be room enough for one?
    More pics if possible?
    /Frido
  11. Guest-16
    Guest-16 Guest
    That's nuts! :D Reaper memory and not Flex! :eeek: Watercool them too!
    Looks pretty crazy and must be a bitch to move.
  12. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    :gasp: silenx fans :gasp:
  13. Robster
    11 Dec 2003
    the crazy client again. Just waiting on the new 45nm chips before going to 4g of water cooled ram. Currently my heat load is greater than phase/change will handle from what i've been told. I'm running at close to 300w heat output on the cpu and the best of the phase change units we've found are around the 200w mark.:thumb:
  14. [MadMan]
    3 Feb 2007
    hmm, 300Wats from cpu?? hmmm, lets say its 3.6Ghz, so for 300W heatload you should run it at ~1.75V I hope not...
    its actualy 180-220W IMHO
    Anyway, nice rig you have
  15. Robster
    11 Dec 2003
    running cpu voltage at 1.65v to race for benchmark but idle temp rises to aprox 53c. can pull down to 1.575 v and idle at 42c but wont run mark 06 but runs everything else. heat load is in excess of 250w at 1.65v so the phasechange would be overworking. Any sugestions welcome:wallbash:
  16. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    i know poeple that run quad core cpus overclocked like yours. you just have to get one custom made. just pc me if youd like me to put you in contact with some one
  17. ComputerKing
    8 Sep 2006
    he is rich boy ;) wooot hope you enjoying your hardware good luck and take care of them
  18. lisimengok
    lisimengok What's a Dremel?
    26 Jul 2007
    that's great!!!!
