Survey: What processor? What Speed? What Temp?
Discussion in 'Hardware' started by Fly, 25 Oct 2001.
  1. Fly
    Fly inter arma silent leges
    31 Aug 2001
    Let's have a bit of a survey...
    What processor have you got, what speed is it running stable at and what temperature?
    I'll start the ball rolling:
    Intel Celeron 800,
    1003Mhz,
    37 Celsius Idle - 61 Celsius Under Load (Torture Tested)
    Fly
  2. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    Athlon 1G AXIA
    1.33Ghz
    32c Idle
    44c Load
    Will do 1.5, but it's way too hot for that.
  3. RTT
    RTT #parp
    12 Mar 2001
    Athlon 1333 AYHJA-R
    @1551Mhz
    36c Idle
    41c Load
  4. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    Athlon 1.4 AYHJA-R
    Stock Speed
    32c Idle
    35c Load
  5. Guest-16
    Guest-16 Guest
    1.4gig Tbird AHYJA
    Stock Speed (need it stable for my work, cant afford to bugger my cpu)
    41 idle
    43-46 load (after 2 hrs Dod and in a warm room)
    case is so packed the 6 case fans dont help much with a case temp of approx 28-31. :(
    If someones got some webspace - ill take a pic later and show you what i mean by packed!
  6. Cheese
    Cheese Doc
    6 Oct 2001
    1gig AXIA Y (I think!) @1.4 (10.5x133 - does 145x10 but I like things cool) runs at 37*C and goes to 39*C load (ACPI turned off!).
    :D
    Cheers,
    r.
    Edit: In my case (juno p3) you will find,
    An IBM 60GXP 40GB,
    Samsung 30Gb hdd,
    Samsung 12 DVDrom,
    20x burner (uses 25watts!!),
    gf2 ultra,
    100Mbit ethernet card,
    TV card,
    SB Player 5.1... all of which produce a lot of heat :D
    I have three case fans, all 2.5W ys-tech 80mm's (2 in, one out), a slot cooler, an 80mm fan strapped atop my ThermoEngine and a small 60mm mounted at a strange angle keeping the air moving around my ram and the hot stop by the gf2 ultra...
  7. Elspuddy
    Elspuddy Minimodder
    2 Oct 2001
    Amd T-bird 1ghz@1.3
    Golbalwin 802
    37C idle (was 50c b4 alipuk cleand my pc :D ) 40+ load
    note i do have 2x 120mm sunon fans on the side of my case
  8. Phil
    Phil What's a Dremel?
    19 Jul 2001
    T-Bird 1.0 (unknown code - bought from OCS as 'guaranteed to 1.15+')
    1.10 (stable)
    1.15 (not at all stable)
    Taisol742
    idle 31
    load 44
    with delta@7000rpm:
    idle 27
    load 38
  9. SuperScrubber
    SuperScrubber Mad Chemist.....buwahahaa
    12 Mar 2001
    AXIA @ 1.4ghz
    Taisol 760
    No extra cooling;
    Idle 30c
    Load 45c (roughly!!)
    With extra cooling (from fans);
    Idle
    Load
    ...........this is with four HDDs (2x60gxp's [RAID 0], a 75gxp and another older IBM), its quite amusing sometimes when the system is actually hotter than the cpu!!
  10. Guest-16
    Guest-16 Guest
    here's my over-packed 802 case. I think ill need a 400/350W PSU soon cause i need to hook up the redundent Harddisk, cooler and Cathode.
  11. Cheese
    Cheese Doc
    6 Oct 2001
    lol that's almost empty... you have seen Super's right? :D
    r.
  12. Guest-16
    Guest-16 Guest
    i think so. from what i remember its pretty nutz :D
    But with 6 blinkin fans there's almost no air flow through it and ive got 30C case temp?????
  13. Cheese
    Cheese Doc
    6 Oct 2001
    Hmm... I take it you've tried amillion different combinations of which ones blow and suck? The only thing is ducting... get the hot air from that cpu of yours outa ya case asap...
    r.
  14. Lordflash
    Lordflash What's a Dremel?
    27 Aug 2001
    Whats that anodised blue thing in the top right corner of your case ? just above the cd / hardrives ?
  15. Lordflash
    27 Aug 2001
    I count 8 fans btw inc the cpu fan
  16. Guest-16
    Guest-16 Guest
    Yup 8, but 6 are case cooling.
    The blue thing is a harddisk heatsink from maplins. Its called: "the ultimate harddisk cooler" and encorporates 2x evercool 40mm fans and a big blue alu heatsink that is pressed onto the top of the harddisk by springs.
    Sorry about the crap 2nd pic, its dark under my desk.
    Blowholes dont work, i dont like them, and when ive tryed them before they've only buggered things up :( soz
    Ive got it in the best combo, side and front "in" and rear and top "out".
    :confused: :confused: :confused:
  17. ChriX
    ChriX ^
    30 Aug 2001
    Super! post a pic of the inside of your case pls...
    Athlon TBird 1Ghz
    @ 1Ghz
    case = 24c, cpu = 40c, ( getting a new cooler )
  18. RTT
    RTT #parp
    12 Mar 2001
    i see youve cleaned out all those daddy long legs then :D:D:D :eek: :eek:
  19. SuperScrubber
    12 Mar 2001
    As requested..............
    First a piccy of its butt.............:)
    .......and secondly an old one of the innards......
    .............enjoy - I do !!!!! :D:D
  20. ChriX
    ChriX ^
    30 Aug 2001
    Ahhh, nice case mate, cheese told meh that the side can hover, I had my doubts, but now I see the light! LOL :D
