System Overhaul!
Discussion in 'Hardware' started by Zmaster2k, 24 Oct 2001.
  1. Zmaster2k
    Zmaster2k You looking at me?
    15 Oct 2001
    My Celery 633@950 needs updating methinks!
    Ok
    Is it worth me getting an XP? when i could get a 1.4?
    Best board?
    How much am i gonna be likly to be spending?
  2. Phil
    Phil What's a Dremel?
    19 Jul 2001
    Best Budget Combination : PC Chips Motherboard (mATX, LMR) for £50 plus a duron 750 for £40 ish
    Best Power Combo - Latest Epox board (8KHA+ ?) and Athlon XP 1800
    or take the middle road and get say an KG7 lite and an athlon XP1500
  3. Phil
    19 Jul 2001
    hmm, just realised the duron option wouldn't be much of an 'upgrade'
    Go with the XP1500 (cheaper than the 1800 by far) and get a nice KG7 or Epox board.
  4. TiTch
    TiTch h2o cooled
    19 Oct 2001
    If you are thinking of the KG7 then wait a couple of weeks for the launch of the KR7 which uses the via kt266a chipset with its greater support for unbuffered ddr, wider bandwidth etc.
  5. Lordflash
    Lordflash What's a Dremel?
    27 Aug 2001
    Yep definatly agree with thatr make sure you get an 266a board might cost you a bit moe than planned as youll have to buy ddr ram to.
