Modding The Laser mod.
Discussion in 'Modding' started by ¥¥¥, 26 Jan 2003.
  1. ¥¥¥
    ¥¥¥ What's a Dremel?
    14 Sep 2002
    Yep i just got in from maplin. I got an entertainment style laser because it was cheaper than buying a seperate laser part on it's own. It creates some nice effects via motorised mirrors and it is quite small.
    I will take it apart and try and mod it to produce adiquite effects for in case display or just extract the laser unit itself.
    Here is more info about the laser.
    http://www.miraclebeam.com/lightshow.asp
    Hopefully I can mod it to get some good effects inside my case, I will continue to investigate the prospect of simulating a visable beam inside the case. I found exposing the laser to a small ammont of smoke vapour resulted in a partially visable beam.
    I will get some action pics up after I get new batteries for my digi cam :)
    If anyone is wondering the laser device cost £40 from maplin.
  2. KMS-oul
    KMS-oul You think you know me.
    1 Aug 2002
    Sounds good man.
  3. eaterofpies
    eaterofpies What's a Dremel?
    12 Feb 2002
    okok so weve had a look at dust etc but why not use smoke . . . use a joss(sp) stick or incense stick makes yer case smell nice at the same time :D (or screw up making an ir reciever and nearly set fire to yer room that makes good smoke :D)
  4. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    I've seen that green laser before. Very impressive, and so powerful. It would be pretty cool to have a mist or fog floating slowly in a horizontal plexi box in the bottom of the case with green lasers on servos moving about... that would be cooooool... like something out of a Sci-Fi movie
  5. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    In physics, my instructor did a laser demo and used a block of a polymer than made the laser visable when it passed through. I don't remember what is was though. It looked like plexy though (I know it wasn't) so you may be able to use it if either myself, or somone else can find out what the stuff is. I dono if it would work for green lasers, but it would sure beat all the tricky mechanics of playing with dust/fog.
  6. ouija
    10 Nov 2002
    More than likely the material would have bubbles or small particles in it for the laser beam to reflect off. You get the same effect if you put a laser along the carpet
  7. ¥¥¥
    14 Sep 2002
    Here is an action pic of me shining the laster into some boiling pasta.
    I will keep you updated on my mod. I'm still reviewing the possibilites.
  8. eaterofpies
    12 Feb 2002
    cant really do that in a case tho :lol: :lol: the steam would start to condense on yer graphics card and :waah:
  9. ¥¥¥
    14 Sep 2002
    How about I shine it in your eyes ok ?
  10. eaterofpies
    12 Feb 2002
    :lol: Chill im just having a laf
  11. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    okay having some experience with partical effects. I suggest you use differen't particle sizes, like using Ultra fine particals (to get smoke that doesn't dissapate) mixed with medium sized particals so you get uneven partical speed... filling that thing would be hard.. and make sure you some how remove any static or else it will stick to the walls (you could inncrease the humidity) anyways it will be a good idea if it works. Also MAking it sound activated or.. such would be awsome
  12. M_D_K
    M_D_K Modder
    3 Apr 2002
    thats a bit mean don't you think hes only trying to stop you from destroying your computer.
  13. [A]MD
    [A]MD What's a Dremel?
    28 Aug 2002
    Sorry to thread hijack, but It seems there is another case modding DDR player on the forums :D
    DDR > *
