Modding Tips for removing back of laptop TFT
Discussion in 'Modding' started by madhatter, 6 Apr 2005.
  1. madhatter
    madhatter What's a Dremel?
    16 Sep 2003
    The time came, and my trusty laptop screen hinge has worn and busted. floppy is the best way to describe it.
    a new laptop is in the post (was time to upgrade anyway) but i'm planning to turn my old one (aka Lucy) into a projector with attached PC, by way of removing the back of the TFT and placing it over an OHP, leaving a suitable gap to allow airflow, perhaps even assisted by a fan or two.
    The laptop in question is an Acer Aspire 1310, and i ask you this - how can i remove the plastic from the back of the TFT (i.e. to make it semi transparent) without damaging the screen?
    Thanks in advance for any help!
  2. Blue Raven
    Blue Raven What's a Dremel?
    25 Sep 2003
    I can't say that this will work for your laptop but with an older one that I took apart, the various sheets of plastic are held in place with a metal bracket. This is probably just a case of removing all the screws you can find until it comes apart and trying to remember how it all fits together.
  3. TheMuffinMan
    TheMuffinMan Minimodder
    26 Apr 2004
    Haven't had experience with yours in particular, but some I've used (think it was an old compaq) used friction tabs to keep most of it in one piece along with some screws at the base, you could jam a screw driver in the seam along the edges, and pry up a bit to see if you see any tabs
  4. Ogami Itto
    Ogami Itto What's a Dremel?
    11 Apr 2005
    Hi This is my first post and thought I would make it a good one.
    Most laptops use some sort of proprietry system to run the screens. So it is not just a matter of simply hooking it up to your graphics card.
    You can buy adapters for some laptop monitors that will make them work, or if you are technical enough and have the time/money you probably could get it to work.
    unfortunately there is no hard and fast rule but if you look hard enough you may find someone who has already done it and could follow their lead as it were.
    *Edit* Oh I forgot to mention, I was going to try this too but after not being able to find the info I needed on how to convert my old laptop screen I gave up. I am now waiting for one of my other LCD screens backlight to die
  5. SJH
    SJH Minimodder
    24 Dec 2003
    Read his post, that's not what asked :rolleyes:
  6. madhatter
    16 Sep 2003
    hehe, yeah it does tend to help if you read the post before you post. aww and it was your first one too - shame you didnt actually make it a good one... :hip:
    i'll try just prising it apart like was suggested, thanks all!
  7. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    Let me first say welcome! I hope you'll stay for a while. Second, forgive the people who post during a sugar crash. We all post occasionally with out fully reading the post. I'll also say the reading the FAQ and rules will save you some grief later. Spelling and gramme are greatly appreciated. But don't let any of this intimidate you from asking questions or contributing to Bit-Tech.
  8. Ogami Itto
    11 Apr 2005
    Try this.
    Check under all the little rubbery bits, and/or stick on covers for all the screws on the screen part only, remove these.
    Then using a very small flat head screwdriver gently tease the sides of the case and you should find it will pop off very easily. Now one of two things could happen here either the front will come off. In the case of the two laptops I tested this was the case. Or the back may come off.
    If only the front comes off you will have to unscrew the screen from the rear of the case and mark it up and cut a nice hole. I reccomend some edging material to finish it off with. Or you could just remove the back of the case, can be done sometimes and the hinges will still hold the screen onto the base without any of the surroundings.
    If you want to post a picture of a removed hinge I might have some spare I have a very broken laptop that would not miss them. They might be some sort of generic fitting. The two laptops I took apart seem to have the same hinge
    Then remove the backlight, which should be a simple case as it will not be mounted too well. Be careful not to flex the screen as you may damage it at this point.
    This creates another small problem, some inverters check to see if the backlight is actually there and requires some sort of "dummy" circuit to fool it into believing it is still there.
    Once reassembled this would give you a laptop that can be placed over an OHP or you could if you feel like having some real fun extend the ribbon cables and other wires so that the screen can be moved away from the laptop altogether
