Case Mod - In Progress TJ07 'Reaper'
Discussion in 'Project Logs' started by montymole, 13 Aug 2015.
  1. montymole
    montymole Rigid Tubist
    24 May 2010
    Hello Guys I have been working on this build in my spare time over the past few weeks as I needed a workstation as my main gaming rig is not finished yet and my last finished one GT3 RS has been sold due to an offer I could not refuse.
    I have been using a test bench as my daily driver and it had to be sorted so I wanted to create a moody and dark PC to suit the MSI X99 SLI Plus board and this TJ07 was the one I used last year for my Red Candy PC it had been an empty shell with need for stripping normally I would take a case and have it dipped in acid but I wanted to do all this myself for that extra bit of pride knowing the toil and hours of work are worth it ..
    Then I took it round to my friends powder coating shop and had it done in a nice matte black the internals did not need stripping or new finish just a clean up as I knew a steel mid plate will be going in and I am not using the optical rails.
    The MNPCTech Feet also got coated they was a little worse for ware and needed some love you can also see the Cooler Master Silencio PWM fans which are very quite and seem to have good Static Pressure .
    So this project has been kindly sponsored by
    The Specs:
    Intel 5820k
    MSI X99 SLI Plus
    980 GTX
    Samsung SM951 256 GB PCIE SSD
    Crucial DDR4 2400 MHZ 16 GB (Ebuyer)
    Crucial BX100 500 GB SSD ( Ebuyer
    Seagate 4TB Surveilance HDD (Ebuyer)
    Silverstone 750W Strider Gold PSU with Black Cable Set
    Silverstone TJ07
    Cooler Master Silencio PWM 120mm fans X4
    EK Waterblocks for CPU . GPU, Fittings , Radiator
    Aqua Computer Aquatube
    MNPCTECH Case Feet
    E22 Ultra Clear
    E22 Laser Etching
    So 1st thing was making the new mid plate this was a piece of 1mm thick steel picked up at B&Q
    drilled and riveted it for that industrial / moody look I was going for in my head
    Got some of the old Caustic Soda out for removing anodizing ..
    Pump is braided and mounted ...
    The rear panel was a Pulse modding one the threads on the PCI brackets were shot and I had no option but to drill them out and use a nut and bolt ...
    Some Hardware shots next ....
    MSI X99 SLI Plus ..
    From SilverStone
    Next some Awesome E22 later Etching ......
    I took some more of the 1mm steel etch primer then matte black and took it over to E22 HQ
    and then this ....
    Riveted again
    The HDD and SSD with the drain tap down below
    Cables at the back
    So next we have pics of the assembled PC so if you do not want to see yet ..........................................................................
    This is where I leave it back later with more pics of the filled loop and some lighting installed bye for now folks. :thumb:
  2. DBRichard
    DBRichard What's a Dremel?
    6 Apr 2014
    That bare looks really nice, that's one awesome looking system bro
  3. montymole
    24 May 2010
    Small update with a few pics I took whilst playing about with the lighting, It is going for a little photo shoot in the morning so I shall be concluding this small project log with some good shots this week.
    These were taken with a very high ISO but the mood of the PC is captured well I feel.
    Bye for now
  4. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Looking great mate!
    J.
  5. montymole
    24 May 2010
    Thanks mate , will have more pics soon Nate took a few of it today I will upload as soon as I get them
  6. montymole
    24 May 2010
    Final Pics
    Hello again folks this is the last update of this brief project log and here are some rather nice photo's taken for my by Nate from E22.
    So happy with these and how the rig has turned out.
    Thanks for viewing.
  7. Icelander
    Icelander Minimodder
    3 Mar 2015
    ;) I loved it...
  8. montymole
    24 May 2010
    Thank you mate appreciate you looking at this :)
  9. hovek
    hovek “Can’t or won’t?” Sterling Archer
    23 Jan 2014
    Still my favorite case! Very well done, simple but effective.
    How's temps with gpu and cpu in parallel? Thinking about the same loop now.
  10. montymole
    24 May 2010
    Thanks for the reply :)
    The Temps are not that bad considering how its set up 45c idle 63 load with 4.4GHz @1.21v
    The D5 needs to be turned up or the flow rate was not enough and this causes a lot of turbulence in the Res but I am happy with the temps and noise overall :)
  11. hovek
    23 Jan 2014
    Thanks man. Will look into parallel a bit since i like how neat it looks.
  12. Gazmtk
    Gazmtk What's a Dremel?
    3 Dec 2014
    The Red Coolant really brings the black and metal look together ;)
    I am about to start a TJ07 build myself and honestly you have given me some inspiration on a few problem area's I had in mind :)
  13. montymole
    24 May 2010
    Thank you , and if you need to know anything about the case just ask me in a PM I know them inside out :)
  14. Cheapskate
    13 May 2007
    Looks lovely. How are the temps with that parallel setup?
  15. montymole
    24 May 2010
