upgrade OS or have a RAID?
Discussion in 'Hardware' started by dawolfman666, 4 Jun 2003.
  1. dawolfman666
    dawolfman666 What's a Dremel?
    10 Mar 2003
    hi, just building my new system Abit IC7-G P4 2.4C 1024mb DDR and SATA Maxtor 120gig HD.
    i am still waiting for my PSU to arravie so i havn't had a chance to fire it up. While waiting i have been getting the lastest driver for everything. I was going to intialy put windows 2000 on it and use Intels RAID migration tool to add a second SATA maxtor drive at a latter date....all fine i thought.....but i read today that this tool is only supported on Windows XP....DOH!
    the cheapest price i have found for Windows XP Pro OEM is £115 and the cost of another SATA Maxtor is around £120
    I think i have few options.
    1. forget about RAID and stick with windows 2000
    2. Buy XP Pro
    3. Buy the extra HD and set up RAID 0 on the other controller and install windows 2k.
    i am stuck...help
  2. *mat-ster*
    *mat-ster* What's a Dremel?
    10 Mar 2002
    In your position I would get XP Pro, that way you can upgrade in the future with less hassle.
    BTW what heatsink do you plan to use ?
    Mat
  3. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    4.kazaa
    ok, nvm that was stupid...id buy the hdd if i were u
  4. CatKing
    CatKing What's a Dremel?
    10 Nov 2002
    well, i think the best is to ask yourself whats the benefits u would get from raid and is it really needed at present.
  5. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Since 2000 is far better than XP anyway, I'd say get the extra HD space, even if you aren't gonna RAID it up...
  6. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    ^---somebodys bias..Xp isnt that bad..i really like the remade start menu. It handles multiple monitors very well...
  7. Kameleon
    29 Apr 2003
    I don't want to get into this age-old discussion yet again, but suffice to say I don't have any major problem with XP, except it has a few bugs that aren't in 2000 and it doesn't seem to do anything significantly better, except look nice.
  8. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    Start listing all the pros/cons of your decision, and chose the choice that is right for you.
    Personaly, I'd go ahead and get XP pro. I like 2000, and personaly think it is a superoir operating system, XP will ease everything from networking down to customizing your start menu. It also has very good dual monitor support ;)
    Edit: Oh, if you download all the updates/service packs, there are not all that many problems with XP anymore ;)
  9. dawolfman666
    10 Mar 2003
    mmmmm....i don't want to put a warez version of XP on it as i can't be arsed with cracking and patching it up so i can install a load of updates on it....i need it as stable as possible.
    i use XP at work and i am slowly liking it...after getting rid of all the wizz bang stuff and making it look like a windows 2000 machine.
    half of me is saying forget XP and go for the speed! but my head says get the OS and sit and wait some more.....grrrrr....increase computer spec decrease my holiday cash....now where's my tent gone?
    I have put on the zalman 7000AlCu heatsink, was a bit of a bitch to get on first time i had used thermal grease dam slipy stuff isn't it? but it does look mighty cool....LOL....just waiting for my phatt 430w Ernmax PSU to come along with some Corsair 3500DDR XMS ram.......so i can fire my new toy up.
  10. dawolfman666
    10 Mar 2003
    can XP do different resutions on each monitor?
    ie 1600X1200 on my 19" and 1280 X 1024 on my 17"
  11. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Yes it can.
    Unlike your shelves! :lol: Looks like they're about to fall off!
  12. dawolfman666
    10 Mar 2003
    certainly swaying towards XP now....uped my res to 1600 and i can't go back now....but i have also got used to doing a dual monitor setup...the best for doing tutorials and video editing
  13. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    I would get the HDD. And if you must have a free, legal O/S, use Linux, it 0wns anyway :) (or stick with 2k which is better than xp)
  14. Drastik
    Drastik Minimodder
    10 Jan 2002
    i would use linux if it would support windows games
  15. Lazy
    Lazy Meow?
    13 Nov 2001
    get xp pro forget raid.
  16. burnoutuk
    burnoutuk What's a Dremel?
    18 Feb 2003
    I agree with that. Just make it look like win2000
  17. Drastik
    Drastik Minimodder
    10 Jan 2002
    i find that if you are using a LEGAL copy of windows you will have no problems, on a side note if everything works fine dont install sp1 its more trouble than its worth, wait till sp2 comes out.
  18. Yo-DUH_87
    6 Mar 2002
    I actualy had more trouble pre-SP1 than after, but that is just me.
    Besides, XP-SP1 adds the ability to change the programs Windows uses by default, nice ;)
  19. Drastik
    Drastik Minimodder
    10 Jan 2002
    well everything works fine for me, then i install sp1 then its a downhill bike race with no brakes :rolleyes:
  20. dawolfman666
    10 Mar 2003
    cheers for the comments guys.
    went fo the safe option...i am showing my age....and got a ordered a copy of XP.....will wait for SP2 to come out though.....does anybody know where the setting is to turn off that dam auotplay thing with a CD and can the file search tool be shown in 'classic' mode?
    will be buying the 2nd HD in september so its not that long to wait.
    I must be grwoing old as this is hte first peice of software i have bought......mmmm...i guess i owe something back after 10yrs
