Modding UV Cold Cathodes
Discussion in 'Modding' started by sTevE, 7 Jan 2002.
  1. sTevE
    sTevE What's a Dremel?
    12 Dec 2001
    What is the color of a UV CC? I have 2 blue CC's and want to add a uv but want them to be all blue.
  2. brutal
    brutal What's a Dremel?
    7 Nov 2001
    the actual "glass" part of a UV CC is black and when lit, they have a purple-ish color, well at least the few that i have seen are.
  3. Cicada
    Cicada What's a Dremel?
    29 Nov 2001
    i have 3 in my case, and they glow purple....
  4. Guest-16
    Guest-16 Guest
    U after a quick tan or something :D:D ;)
  5. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    Yep, They look purple. I would have thought this would go quite well with a couple of blue ones!:cool:
  6. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Definitly look purple to me however my camera thinks they are blue :/
  7. Alaric
    Alaric code assassin
    3 Nov 2001
    /me loves purple
    might buy me a blue and a uv one
  8. sTevE
    12 Dec 2001
    so you dont think uv and blue would look messed up?
  9. macroman
    macroman The One
    3 Sep 2001
    If you use the plastic tube the CC come in to mount it. The tube glows blue! ;)
  10. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
    reminder - dont look directly at them if you can help it!!! my head still hurts from last week!
  11. Alaric
    3 Nov 2001
    no steve i think blue and uv would look mighty fine :D
  12. Jamie
    12 Mar 2001
    :) I wish there was a camera that could take images of UV that makes it look as good as it does in real life :)
