Development VB6 IRC Client-where to start?
Discussion in 'Software' started by DickH, 17 Apr 2005.
  1. DickH
    DickH What's a Dremel?
    6 Jun 2004
    I would like to make my own IRC client, but can only do it with Visual basic 6. Where should I go to figure out how to communicate with an IRC server?
  2. Dinh
    Dinh What's a Dremel?
    27 Jun 2004
  3. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    no no no.
    read the RFC
    www.rfc-editor.org
    1459 iirc.
    using VB6 will be a pain for this.
  4. Henchman:crg
    Henchman:crg What's a Dremel?
    9 Feb 2005
    Good luck using the RFC site, I had to use this for doing http uploading, but the documentation on this site was awful :miffed:
  5. DeX
    DeX Mube Codder
    22 Jul 2002
    I used the IRC RFC to create a simple VB6 program to connect to an IRC server, join a channel and send commands. I didn't get further than that but it wasn't hard to do.
    I agree with you TheAnimus in that you shouldn't just download a premade program because learning from that will take 10 times longer than learning from scratch. But I disagree (once again) that VB will make it a pain. An IRC client requires lots of string parsing and VB is perhaps the second best language I've used to do this. PHP is probably the best but it would be silly to make an IRC client in PHP. :)
  6. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    String parsing in VB is only beeten by:
    Perl
    C#.NET
    VB.NET
    J#.NET
    Python (and Python.NET)
    PHP
    MASM32 (with strings macro lib)
    C++ (with strings lib)
    C__ (you can have delimiters etc)
    erm, pretty much any language i've ever come accross.
    but thats besides the point.
    The reason this will be hell in VB6, is that theres no native support for a v2 RichEdit, so you can implement all the colouring easily (the background colour on the text). Its not a good OO lang, so you can't easily make a "channel" class that handles that channel, so to support another channel you just add a new channel, same goes with servers. WinSock support is a bit naff too.
    I actually made a simple one channel IRC client in VB before for kicks, so this isn't religous predudice. .NET would be a much better language for this.
  7. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
  8. DickH
    6 Jun 2004
    I guess I need help with sending and recieving info from the net before I get to the IRC part, does VB6 have any commands or anything for sending/recieving info online?
  9. ColD_FusSioN
    ColD_FusSioN What's a Dremel?
    26 May 2004
    check out the posibilities of interfacing with netcat, there is more info on
    commands
  10. ColD_FusSioN
    26 May 2004
    are you familiar with winsocks??? there is an object (OCX) to do TCP connections in VB6
  11. DickH
    6 Jun 2004
    nope, not at all
  12. ColD_FusSioN
    26 May 2004
    Socks!!
    In VB6 you can add the winsocks control to your project from "Project/Components..." selecting Microsoft Winsock Control 6.0.
    In www.freevbcode.com you can get very cool examples to know how to use it, if this is the first time you are going to use winsocks, check this example
    Hope that helps... :rock:
  13. DickH
    6 Jun 2004
    Im trying to use winsocks, but I get this error everytime
    "License information for this component not found. You do not have an appropriate license to use this functionality in the design environment."
    I looked up the problem and download what was suposed to be the fix from microsoft, but it didn't fix it.
  14. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    could be a security rights issue, you running as admin? check your active-x rules.
    if you can afford it, get a copy of VB.NET its not as nice as C# in many ways, but its good none the less.
  15. ColD_FusSioN
    26 May 2004
    what service pack do you have?? :confused:
  16. DickH
    6 Jun 2004
  17. DeX
    DeX Mube Codder
    22 Jul 2002
    Try running this from the Run box:
    regsvr32 MSWINSCK.OCX
    Then add it to you project by going to Components and finding the Microsoft Winsock Control 6.0.
    Then read the Winsock Control tutorials on this site:
    http://www.vbip.com/winsock/index.asp
  18. DickH
    6 Jun 2004
    thanks, the link to the info on winsock was almost exactly what I need, however I still have the same problem when I try to add it to a form. Do you think reinstalling vb6 would fix it?
  19. DeX
    DeX Mube Codder
    22 Jul 2002
    You could try reinstalling but that doesn't usually fix it. You've tried using revsrv32 to register the ocx right? And you've tried this program from MS which usually fixes the problem right?
    http://support.microsoft.com/kb/q194751/
    If those two things don't work then try reinstalling VB. Otherwise I don't know what you can do.
  20. Dinh
    27 Jun 2004
