Graphics video display problems with 77.72
Discussion in 'Hardware' started by Neogumbercules, 3 Jul 2005.
  1. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    Does anyone else experience a very whited out scene when playing AVI files with the new nvidia drivers? Everything appears washed out and the color is all off.
  2. Springs
    Springs Boing boing
    29 Aug 2004
    yes i have the exact problem.... they appear to be to bright... sucks really... any video file i play is like it...
  3. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    check video overlay colour settings?
  4. Springs
    Springs Boing boing
    29 Aug 2004
    i rolled back mine to 77.30 all is good now...
  5. Neogumbercules
    14 Aug 2004
    Ok, I will try 77.30
  6. Link2425
    Link2425 What's a Dremel?
    16 Jun 2004
    I saw the same problem I went into the color controls and changed a couple things around. I think I set the drop down menus to desktop and standard respectively and hit restore defaults or something like that. Whatever I did it fixed the problem. Playing with those is one option but I guess rolling back the driver is just as good.
  7. tamffc
    tamffc What's a Dremel?
    5 Oct 2003
    i had the same problem rolled back to 77.50
  8. Rufus-Seal
    Rufus-Seal Guest
    Right click on desktop -> Properties -> Settings -> Advanced -> tab of your videocard -> Color Correction -> Aply changes to Overlay -> below Color Profile chose Advanced -> Apply.
    That will do the trick;)
  9. slugs
    slugs Minimodder
    4 Dec 2001
    thanks for that. i guessed it was under that setting and managed to make things worse. didn't try advanced that puts it back to nice flat profile
  10. Rufus-Seal
    Rufus-Seal Guest
    You're welcome :thumb:
  11. toyomatt84
    toyomatt84 What's a Dremel?
    1 Jun 2004
    Thank you Rufus, solved my dilemma. :D
