Hi everybody! (Hi doctor nick) I'm sitting here and looking for a "how to" guide about Water chillers, bu i can't find one. So i was thinking maybe you know where there is a guide about how you make a water chillre with a 80-226W peltier? //KAK1000
#2 - Well I was thinking about a thing where you make a reservoir with a cold coolerprofile points down in to the water and cool's it down to somewhere below zero
Ooh, me? I don't know anything about waterchilling Was just trying to be helpful so threw you a link. Sorry dude!
Why not just cool a bit of tube? and then mount the heatsink on the the tube - if you used copper you could just solder them together. If you where to get fancy - grab a block of copper - drill a hole - tap - barbs...then place a pelt on top of it - and a heatsink on top of that. If you get below room temp though u are going to get condensation problems.
because it would be a lot cheaper to use a normal Alu heatsink and custom make a plexi reservoir, and i think it will give better results... i'm hpoing to get my water someehere about -6*C
